I install SDK 3.13. When I try to make project with Project Wizard I get following error:
[wmcheck error #16] Unable load IDE settings (…path…oatrc file not found)
I also get this error if I run wmcheck in command line.
The file is the path. Here is what is in file:
export WM_OAT_IDE_OS_DEFAULT=“C:/OpenAT/OS/3.12.05”
export WM_OAT_IDE_FW_DEFAULT=“C:/OpenAT/Firmware/657_”
export WM_OAT_IDE_PLUGINS=“C:/OpenAT/Plug-ins”
export WM_OAT_IDE_GTS_GCC=“C:/OpenAT/IDE/GCC/4.0.1.0”
export WM_OAT_IDE_GTS_MINGW=“C:/OpenAT/IDE/MINGW/3.8.0.0”
export WM_OAT_IDE_ECLIPSE=“C:/OpenAT/IDE/Eclipse/3.1.2”
I have re-re-re-re-reinstalled SDK. No help.
Any ideas?
/murjan
