Hi everybody,
Unfortunately, I was not able to figure out from the ADL User Guide what the meaning of wm_apmCustomStackSize is now. Is this the stack size in bytes or in elements of 32bit (as in previous versions, where we had to define the stack variable ourselves)?
Did I miss anything here, or is that indeed not clearly stated in the documentation?
In section 3.1.2 in Note 3 “kilobytes” is mentioned in an e.g. sentence but I think it is missing to explain what the wm_apmCustomStackSize parameter should be in this case. And since according to Note 1 the wm_apmCustomStack constant “is now completely internally processed by the Wavecom OS” I have no definition that I could infer the size of the stack in kilobytes from.
I guess I will be able to find out the true stack size with adl_memGetInfo() but I think this should be clearer in the documentation…
Best Regards,
Jan
