Hi
when I turn ON the wismo I can write AT and the answer is OK…after a few seconds the Wismo tell me *PSSTK… and then not answering anything again.
AT
*PSSTK: “SETUP MENU”,1,4,“Vive tu SIM”,0,0,1,0,0,8
AT
AT
this is a command from the SIM TOOLKIT.Can I disable it?
Thank you!
Ivan L.
Hi
I guess you can disable it…Try giving at*PSSTK=1 and then perform a reset.
sushil
3
Try AT*PSSTKI=2 or 3 to enable autoreply of STK.
AT*PSSTKI=2 is enabled by default staring firmware L21.
IOLine
4
Hello, can someone explain to me insert Pin on wismo288?
already tried the command will
AT + CPIN = xxx
AT + CPIN: xxx
Dame always error
- CME ERROR: operation not allowed
Help Please
