WISMO218 AT command don't response
My project used a WISMO218 module.
When i turn on, module responsed:
*PSSTK: “SETUP MENU”,1,4,“Super SIM”,0,0,1,0,0,10
*PSSTK: “END SESSION”
then, i send “AT” CTRL+Z command to WISMO218 in main uart. it do not response “OK”.
it send back “AT”.
i don’t understand.
please help me, thanks
regarsd
Why Ctrl+Z :question:
Thank for your help.
I send sms message.
  1. when power on, i pull ON/OFF pin down GND in 1 sec. After, pull it up.
  2. then, send AT command config module:
  • AT //Autobaudrate
  • ATE0 //Echo off
  • AT+IFC=0,0 //No flow control if you use 2 wire mode
  • AT+CMGF=1 //Test mode
send CR character(dec: 13, hex: 0D) after every command.
3.I send message:
  • AT+CMGS=“phone number”
  • send CR
    module response: >
  • send your msg.
  • send CTRL_Z
sms is send.
I have a other problem. I unable receive the sms.
i try to config AT+CNMI = 1,1,0,0,0 and send sms. But any msg is received.
please help me.
Phan.
Ok. My WISMO218 received sms.
My sim memory was full.
regard,
Phan
Hello Dear friend
are you connected RTS , CTS , DTR ,DSR also?
thanks
