hi,
Im using HTTP(POST)method for sending GPS data through GPRS. While transmission of data Wip_cev_error -989 occurs which means NO Route To Host. Can anyone reply how to solve this problem.
hi,
Provide a route to the Host!
You’re not trying to access a Private IP address, are you…?
Yes im using a private IP address with port number for reaching server
You need to explain that in more detail!
It’s the Server that needs the Public IP Address…
What happens if you try to reach the same server from a PC (where the PC is not on the same network as the Server)
