Hi all,
Is it possible to use wip_bearerOpen and wip_bearerSetOpts to set up IP network with WCDMA as bearer on a SL808X module?
With GPRS it works OK, and haven’t tried GSM dialling.
Hi all,
Through WIP APIs, there is no option to set the WCDMA bearer. Will keep you posted if i’ll get some info.
I tested this. The bearer is not supported. You should get an error “WIP_BERR_NO_DEV” which means ‘The device does not exist’.
