Hi there!
I can’t seem to get WIP (wip_writeOpts and wip_readOpts accross UDP) working correctly when using low level interrupts (TCU service, as well as adl_audioStreamPlay and adl_audioStreamListen).
More specifically, I’m trying to stream real time audio to the Q2687 module I’m using. This entails recording/playing and receiving/transmitting 33 byte packets (GSM 06.10 codec) every 20 ms. I’m currently testing upload and download separately, and not having a lot of success.
It seems that when the underlying WIP library is writing or reading data to or from the bearer channel, the moment a low level interrupt occurs, WIP fails to read any data correctly (or simply stops functioning).
- Recording: When using the ADL adl_audioStreamListen interface (low level interrupt that triggers every 20 ms), and I try write any data to the UDP channel, wip_writeOpts fail with the error code -39. The only processing that is occurring in my low level interrupt is copying the data passed to the interrupt to another buffer, and raising a ADL event with adl_eventSet (where I then try and transmit data in the task waiting for the event to occur).
Eventually, what I tried was starting / stopping the adl_audioStreamListen interface, and only then transmitting the data. This works, but the audio quality suffers due to missing incoming PCM frames. To try and localize the problem, I also used a 20 ms TCU timer (replacing the adl_audioStreamListen low level interrupt), and I got precisely the same errors.
- Playing: Similarly, when I use the adl_audioStreamPlay interface (low level interrupt that triggers every 20 ms), the incoming UDP packets causes both the play interface (the low level interrupt stops triggering), as well as the wip_eventHandler_f function waiting for UDP events to “stall” (the embedded module does not reset and no backtraces are generated).
My GPRS bearer gets initialized on the main task (as well as the adl_audioStreamListen / adl_audioStreamPlay interfaces). I am currently trying to move my wip_UDPCreateOpts() call to a task of its own (it’s also currently spawned from the main task), but can’t seem to get it right. wip_UDPCreateOpts returns 0 when trying to spawn from another task. I read on another forum post that I should pass the assigned IP (received during bearer creation) to wip_UDPCreateOpts when spawning from another task, but it doesn’t seem to make a difference.
I also used the variSpeed interface to boost up the clock rate. This delayed the write errors, as well as the receive errors, but they still occurred eventually.
In summary, will spawning the wip_UDPCreateOpts from another task than the main task make a difference when working with low level interrupts?
I would really appreciate any help, thanks in advance.
My current setup:
- Sierra Q2687 module.
- Developer studio: 2.1.0.201108081252
- Open AT software suite: 2.35.0.201103111042
- Firware package: 7.45.0.201102220653
- Open AT OS package: 6.35.0.201102280758
- WIP: 5.41.0.201102280815
- ARM EABI GCC toolchain
- eddy.
