I’m new with WIP library and I’m developing an application on Q2686 using UDP via GPRS. The system must connect and disconnect many times for day.
To check how WIP works I wrote this simple application, based on udp client example included in development system.
In this example with AT+GPRS=1 you can start GPRS and send UDP packets and receive them, AT+GPRS=0, close UDP channel and GPRS.
After I close (AT+GPRS=0) and then open again connection, I don’t receive any UDP packets but I can send… I close and open connection for about 4-5 times and I receive an error from WIP because the handle of created UDP channel is 0.
It looks like that the UDP channel’s never closed although I used wip_close() command before closing GPRS.
I tried to use a delay between wip_close and bearer_stop but no success.
I attach the code, hoping it can be useful and any advice is appreciate.
Thanx
Raff
int r;
TRACE (( 1, "Embedded Application : Main" ));
/* Initialize the stack */
r = wip_netInitOpts(
WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART1, /* WIP traces on UART1 */
//WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_UART2,
//WIP_NET_OPT_DEBUG_PORT, WIP_NET_DEBUG_PORT_TRACE,
WIP_NET_OPT_END);
cfg_gprs(appli_entry_point);
void cfg_gprs ( void (* entry_point)(void)) {
appli_entry_point = entry_point;
adl_simSubscribe( evh_sim, GPRS_PINCODE);
void evh_bearer( wip_bearer_t b, s8 event, void *ctx) {
int tmr_handler;
ascii IpAddr[16];
wip_in_addr_t appIpAddr;
s8 ret;
ascii string[100];
s8 bearer_ans;
switch(event)
case WIP_BEV_IP_CONNECTED:
adl_atSendResponse ( ADL_AT_UNS, "WIP: connected\r\n");
wip_bearerGetOpts(b, WIP_BOPT_IP_ADDR, &appIpAddr, WIP_BOPT_END); //This API provides IP in network format (i.e u32 number)
wip_inet_ntoa(appIpAddr , IpAddr, 16); //This API converts the u32 IP address to a dotted notation IP address.
wm_sprintf(string,"WIP: IP %s\r\n",IpAddr);
adl_atSendResponse ( ADL_AT_UNS, string);
appli_entry_point();
break;
case WIP_BEV_IP_DISCONNECTED:
adl_atSendResponse ( ADL_AT_UNS, "WIP: disconnesso\r\n");
break;
case WIP_BEV_CONN_FAILED:
adl_atSendResponse ( ADL_AT_UNS, "WIP: WIP_BEV_CONN_FAILED\r\n");
break;
case WIP_BEV_STOPPED:
adl_atSendResponse ( ADL_AT_UNS, "WIP: WIP_BEV_STOPPED\r\n");
bearer_ans = wip_bearerClose(bearer_handle);
break;
default:
adl_atSendResponse ( ADL_AT_UNS, "WIP: altri errori\r\n");
break;
static void evh_sim( u8 event) {
int r;
if( ADL_SIM_EVENT_FULL_INIT != event) return;
adl_atCmdSubscribe("AT+GPRS", GPRSCmdHandler, ADL_CMD_TYPE_PARA | 0x11);
void GPRSCmdHandler(adl_atCmdPreParser_t *parser)
s8 returnValue;
char *parameter;
int startStop;
int r;
wip_bearer_t b;
s8 bearer_ans;
parameter = wm_lstGetItem(parser->ParaList, 0);
startStop = atoi(parameter);
if (startStop == 1)
r = wip_bearerOpen( &bearer_handle, "GPRS", evh_bearer, NULL);
r = wip_bearerSetOpts( bearer_handle, WIP_BOPT_GPRS_APN, GPRS_APN,
WIP_BOPT_LOGIN, GPRS_USER,
WIP_BOPT_PASSWORD, GPRS_PASSWORD,
WIP_BOPT_END);
r = wip_bearerStart( bearer_handle);
else
if (startStop == 0)
adl_tmrUnSubscribe(tmr_handler,evh_timer,ADL_TMR_TYPE_100MS);
wip_close(socket);
bearer_ans = wip_bearerStop(&bearer_handle);
else
adl_atSendResponse ( ADL_AT_RSP, "\r\nERROR\r\n" );
return;
adl_atSendResponse ( ADL_AT_RSP, "\r\nOK\r\n" );
static void evh_timer( u8 tmr_id) {
wip_debug("write MESSAGE\n");
wip_write( socket, MESSAGE, sizeof(MESSAGE));
static void evh_udp( wip_event_t *ev, void *ctx) {
wip_in_addr_t addr;
int nread;
ascii string[100];
ascii ipd[15]="";
u16 port;
u8 buffer [30];
u16 len;
switch( ev->kind) {
case WIP_CEV_OPEN:
wip_debug( "[SAMPLE] UDP socket ready, starting the timer");
tmr_handler = adl_tmrSubscribe( TRUE, 10*INTERVAL,
ADL_TMR_TYPE_100MS, evh_timer);
break;
case WIP_CEV_READ:
wip_debug ("[SAMPLE] A datagram arrived\r\n");
nread = wip_readOpts( ev->channel, buffer, sizeof(buffer),
WIP_COPT_PEER_ADDR, & addr,
WIP_COPT_END);
wip_inet_ntoa(addr , ipd, 16); //This API converts the u32 IP address to a dotted notation IP address.
wm_sprintf(string,"[WIP] IP %s data %d\r\n",ipd,len);
break;
case WIP_CEV_ERROR:
wip_debug( "[SAMPLE] Error %i on socket.\n",
ev->content.error.errnum);
if( wip_getState( ev->channel) != WIP_CSTATE_READY) {
wip_debug( "[SAMPLE] Error is fatal, closing\n");
adl_tmrUnSubscribe( tmr_handler, evh_timer, ADL_TMR_TYPE_100MS);
wip_close( ev->channel);
break;
void appli_entry_point() {
ascii string[100];
socket = wip_UDPCreateOpts( evh_udp, NULL,
WIP_COPT_PEER_STRADDR, PEER_STRADDR,
WIP_COPT_PEER_PORT, PEER_PORT,
WIP_COPT_END);
wm_sprintf(string,"[WIP] UDP handle 0x%x\r\n",socket);
