The pinout in the PTS defines the pins 8 as SDA and 10 as SCL for the I2C bus. On the other hand the AT command interface guide says that the I2C bus pins are selected among GPIOs using the +WBM bus management command. The same applies for the SPI bus. Which document is the correct one?
Well, I found on the ADL user guide that the Q24 has a hard I2C apart from the soft I2C. It seems that the hard I2C uses dedicated pins 8 and 10 while the soft I2C uses GPIOs. This should be better documented.
