What is my IP address?
Does anyone know how I check my FastTrack Supreme 20 IP address?
I see that now my GPRS is showing FULL SERVICE. But still no IP Address. Following commands are not very helpful.
AT+CGPADDR
+CGPADDR: 1,
I am not seeing any “+CGPADDR: 2,” entry that shows IP address.
Do I need to enable something?
If there is a static IP that my provider is assigning, where would I see that?
Haiden
does your connection actually work?
(can you ping an address? )
statically or dynamically, if you provider assigns is, it doesn’t matter, it should show with AT+CGPADDR
if you put it in manually, then it’s a different story i suppose…
