It’s actually the opposite, I am looking to establish the connection using Linux, and after the firmware update I am able to see the test network but the AT Port disappeared, I am using Ubuntu 22 and qmicli using MBIM.
Is there any way to pass parameters like the one we used for windows but in Linux?
In windows I can see two com ports, but in Linux I still only see one, maybe I need to set the Usbcomp using AT commands in Windows and then try it in the Linux machine?
If AT port is enumerated in Windows, it should also be enumerated in linux.
So I don’t think now module has problem, probably you need to check the linux USB driver.
