Hi
I use Windows 10 LTSC version and I install GenericDriverSetup.exe (5087) but I got yellow mark the detail is below:
How do I solve this problem?
How about using one RMNET only?
seems same issue as this one:
Hi @jyijyi ,
Yes, I think this maybe the same issue but I still not work with windows 10.
BTW I also try windows 10 21H2.
Should I enable ECM by usbcomp command?
I enable all the port by following commands.
at!entercnd=”A710”
at!usbcomp=1,1,480d0d
didn’t you already enable ECM interface?
didn’t you already enable the “8” in at!usbcomp=1,1,480d0d
Hi @jyijyi,
I think I should use RMNET, there has yellow mark.
seems your WIN 10 has some problem:
Hi @jyijyi ,
I used windows 10 pro 21H2.
And I also got the ECM interface yellow mark.
Should I install ECM driver and where can I get the driver ?
the driver is the same as before:
https://source.sierrawireless.com/resources/legato/drivers-for-wp75xx_wp76xx_wp8548-series-modules---latest-release/#sthash.140kjZxG.dpbs
you can use 7zip tool to extract so that you will see all the driver
