Hello!
I’ve installed m2mstudio 1.0.2, then created a new “OpenAT Project”, imported packeges from “Wavecom Open AT Software Suite v2.20.exe” and tried to run a simple main program aka “hello world”. But I’m receiving an error during building:
/projet/gsmmi/int/cfo/open-at/OS/OSbuild/libs/adl/gcc/out/adl_defaut_tasks.c undefined reference to `adl_main’ Test line 34 C/C++
I’m pretty new to wavecom solutions, so may be I’ve forgot to do something obvious?
Did you use a Wavecom provided sample, or one of your own?
You can select the provided Hello World sample on the third page of the Open AT project creation wizard…
I guess you miss the adl_main function or the adl_initTasks table mandatory definition in your application
Now I’ve got another problem, a bunch of problems to be correct
First of all, I’d like to know, if i need the same version of Firmware on both module and m2mstudio? Because I have version R7.1b installed on module, and software packeg comes with R7.3. May be this is the root of all the evil (dunno if there is such phrase in English ). Because the debugger fails to lunch in “target” mode and I can not see the output of any of the included application examples.
I strongly recomend you to use the same firmware version in M2M studio and on the module. Usually I have some new building warnings, and allways I have had problems with the RTE executions (TRACES, debuging…).
