I’m trying to update my WP7702 for production like I have done with the WP85 for all of our previous builds. We had issues with role back of the WP85 so we build a full SPK that includes the correct version of Linux (built by Sierra), the modem firmware and Legato with our apps. I can’t get this to work on the WP7702.
Every time I fwupdate download either a full combined SPK or just Legato with my apps as a .cwe the WP7702 won’t start Legato. The only way I can get my apps to run is by using the update <file.upate> command.
I have captured console for both situations which I have uploaded.
Legato Starting.txt (21.6 KB)
Legato Not Starting.txt (25.7 KB)
Here is my process:
Run a fwupdate WP77xx_Release14.1_GENERIC_GCF_PTCRB.spk this is meant to upgrade the factory installed version of Legato to V14.1.
Build my apps with Legato used Leaf swi-wp77_5.0.1 to get version 14.1.
Covert my update file to .cwe using systocwe
Run fwupdate on my .cwe file.
After this Legato won’t start.
jyijyi
February 11, 2022, 4:55am
2
I would suggest you to modify wifi.sdef and then “make wp77xx” instead of using systocwe:
you can go to legato-19.02.0/modules/WiFi/wifi.sdef, under “apps:” section, add e.g. $LEGATO_ROOT/apps/sample/helloWorld/helloWorld.adef Now the new app will be included in legato.cwe. Please also note that the max size for legato partition is...
@jyijyi I’m not following. I don’t have WiFI on my custom board and I wasn’t using it with the WP85 either. Why do suggest using “make wp77xx” instead? I successfully used the systocwe method with the WP85.
jyijyi
February 11, 2022, 5:25am
4
If you don’t need the wifi stuff, you can comment out in the wifi.sdef file
“make wp77xx” is a way to compile out the legato.cwe, that is why I suggest this.
I never used systocwe, so I cannot comment why it is not working on your side.
@jyijyi Ok thanks. I’m still not following your suggestion. Can you provide some more details? What is the issue with using systocwe?
jyijyi
February 11, 2022, 5:40am
6
I don’t know, I never use systocwe as “make wp77xx” is already working fine for me to build the legato.cwe
@jyijyi I tried that and I still get the same result. Any other thoughts?
jyijyi
February 11, 2022, 6:19am
8
how about this default legato.cwe by “make wp77xx”?
i.e. not modifying anything in the legato source
How about the official legato image in here?
https://source.sierrawireless.com/resources/airprime/software/wp77xx/wp77xx-firmware-release-14,-d-,1-components/#sthash.9CXru0Ey.dpbs
Yes, the official image works, as I detailed in my first post. I need my apps to work for production.
jyijyi
February 11, 2022, 6:21am
10
how about the default legato.cwe by “make wp77xx”?
how about the image in leaf?
e.g.
/home/owner/leaf/leaf-data/swi-wp76_4.7.0/wp76-legato-image/
@jyijyi Moving to the ./leaf-data/current/wp77-legato and running make wp77xx got everything working.
Turns out the actual issue is the size of the .cwe image. See this post WP7702 R14.1 Available Memory Mismatch
