My FX30S is connecting to Chunghwa Telecom Cat-M1 network in Taiwan.
Hi Jes, James,
Thanks for your feedbacks.
Weâve confirmed the issue we were suspecting.
When ULPM is triggered, the PSM is enabled in the device by default with fallback strategy on ULPM so that if the network supports PSM then ULPM is never actually used.
Weâre planning to fix this configuration issue in next 3.2 RC6 coming within 2 to 3 weeks.
Hi, CĂ©dric,
Thatâs great. Looking forward to test with the new release.
James
That sounds really great. As you have identified the source of the problem, can you perhaps provide a workaround for the existing firmware revisions?
This bug has really delayed our development and if we could have a workaround we will save a couple of weeks.
Jes
Hi all,
Unfortunately, if in your solutions you are using Octave ulpm/shutdown
resource to enter ULPM, then there is no immediate workaround.
However, if you are able to issue a Linux command, then a workaround is to directly write to the kernel swimcu sysfs nodes:
echo 6 > /sys/module/swimcu_pm/boot_source/enable
6 value will allow to enter ULPM only and not PSM.
Nicolas
Hi Nicolas,
Thanks a lot. Can you by any chance come up with a trick to execute shell commands based on something in Octave? I imagine a shell script running on the FX30 monitoring a resource using dhub or something more elegant. I donât have the Legato build chain setup up and I really donât know much about it.
Jes
If future Octave FW could add a resource for developer to send Linux or AT command, that would be a great tool for troubleshooting and issue work around in the future.
After Octave ulpm/shutdown command, I used AT+CPSMS=0 to disable PSM then FX30 can enter ULPM. Therefore if there is a resource where I can issue AT command, I can have a quick fix with Edge Action before the new FW is ready.
3.2.0.rc6 is just out and should be available in your company for FOTA.
It should fix the ULPM issue.
Nicolas
This issue has been fixed in Octave 3.2.0 which is available to everyone on the platform:
Bug Fixes related to ULPM in this release:
Fixed ULPM boot reason that was sometimes not set after wake up.
Fixed an issue in ULPM where PSM was entered instead of ULPM.
I also hit the [jameshorng] problem. I used pmtool: identical result. On power up, the modem shutdown before ssh access (to fix it) was available.
I regained ssh access by removing the aerial. The shutdown was happening as soon as the correct time was provided by the network.
Once I had command line access, I was able to use AT+CPSMS=0; this stopped the shutdowns.
My firmware is newest available, on non-Octave FX30.
FYI, This entry is more relevant to the non-Octave based version of the FX30 forum at the following link.
We do appreciate all forum posts.
