I am testing FX30S device and have referenced ULPM documentation and posts in this forum. Both appear to be quite dated. I am running the latest FW, but cannot get ULPM to work. I verified that PSM does not appear to be running , so not a conflict. Could I get a complete current example I can use to set this up to test? I would also appreciate some estimate / guidance regarding how long ULPM duration should be maintained in order to avoid the wake-up power spike costs to exceed the benefits of ULPM power saving.
Hi @dpinc,
Please refer to Controlling Ultra Low Power Mode section at the following link: Controlling Ultra Low Power Mode
Hi @dbporterhouse
You are right the “Add Event” button has disapeared from the :command stream. This is a bug, and we apologize for that. I created a ticket and assigned it to the concerned team.
To send a command easily, you can use the Resources page and click on the Command icon of the related resource.
That is to say, to trig ULPM shutdown:
Hope this helps,
Nicolas
