I’ve got an application where I’ve been using TCP, now I’m trying to swap to UDP. I have been using Docklight to set up a server.
Once the bearer is setup I have tried to setup my UDP connection through. I know it works up to this point because I have used it for my TCP application.
UDPChannel = wip_UDPCreate (UDPEventhandler, NULL);
wip_setOpts(UDPChannel, WIP_COPT_PEER_PORT, 25000, WIP_COPT_PEER_STRADDR, “xx.xxx.xxx.xx”, WIP_COPT_END);
then from within my UDP Event handler, once I get WIP_CEV_OPEN and WIP_CEV_WRITE, i do
write_Return = wip_writeOpts(UDPChannel, DataWriteBuffer, 7);
where my DataWriteBuffer is an ascii pointer to “1234567”
I get no connection though in Docklight and do not receive any data even though I get no errors from my code.
Is there something obvious I am missing in my UDP setup?
Thanks in advance
