[attachment=0]TCP.jpg[/attachment]
Hello Sierra Wireless world,
I have a litte Problem connecting a Terminalprogram via FXT 009 with a Server.
The connection between the Terminal and the Modem works fine and the connection from Modem to Server, too
My problem is, that I can’t hand over the pointer from my UART programm to my TCP programm. The pointer (ptrbuff) shows the data which comes from the terminal.
This is the UART programm:
void cbUART1Rx (void)
u32 NbTbRead = UA_ZERO;
u32 NbRead = UA_ZERO;
s32 Ret = OK;
u32 Idxbuff = UA_ZERO;
eChStatus_t WriteRet = CH_STATUS_NORMAL;
static bool BuffFull = FALSE;
TRACE ( ( UA_UART1_TRACEID, "[cbUART1Rx] Task Context [%d]",
adl_ctxGetID ( ) ) );
// create Uart1 Event
Uart1EventHandle = adl_eventCreate ( UART1_INIT_TX_RX_MASK );
TRACE ( ( UA_UART1_TRACEID, "cbUART1Rx [%x]", Uart1EventHandle ) );
//Received Data are just forwarded to UART2 ...
while ( UA_INFINITE_LOOP_COUNTER )
TRACE ( ( UA_UART1_TRACEID, "Wait for a Received Data......" ) );
// wait for Rx Available event
Ret = adl_eventWait ( Uart1EventHandle, UART1_RX_EVENT_WAIT_MASK,
NULL, ADL_EVENT_WAIT_ALL,
ADL_EVENT_NO_TIMEOUT );
TRACE ( ( UA_UART1_TRACEID, "Wait for a Received Data......[%d]",
Ret ) );
// clear Rx Available event
adl_eventClear ( Uart1EventHandle, UART1_RX_EVENT_WAIT_MASK, NULL );
ptrbuff = ( u8* )buffer_pool[ Idxbuff ];
Idxbuff ^= 1;
wm_memset ( ptrbuff, UA_ZERO, UART_MAX_DATA_SIZE );
for ( NbTbRead = UART1_MAX_DATA_SIZE;
( NbRead = uart1_itf.read ( Uart1Handle, ptrbuff,
NbTbRead ) ); )
TRACE ( ( UA_UART1_TRACEID, "Read Data Size : %d", NbRead ) );
//Point at first free byte position in the receive buffer
ptrbuff += NbRead;
// Compute maximum allowed amount of bytes to be read
NbTbRead -= NbRead;
TRACE ( ( UA_UART1_TRACEID, "Data is : %d", NbRead ) );
if ( !NbTbRead )
// No more available space
TRACE ( ( UA_UART1_TRACEID, "Read buffer is FULL" ) );
BuffFull = TRUE;
adl_eventSet ( Uart1EventHandle, UART1_RX_EVENT_WAIT_MASK );
break;
} // END of Data READ
// Alpha Rx chars in lower case are put in upper case and in upper case
// are put in lower case
for ( NbRead = ( UART1_MAX_DATA_SIZE - NbTbRead ); NbRead--; )
if ( isalpha ( *--ptrbuff ) )
// Char in lower case goes in upper case and vice & versa
*ptrbuff ^= ' ';
// Processed data are sent to UART2
if ( NbTbRead != UART1_MAX_DATA_SIZE )
TRACE ( ( UA_UART1_TRACEID, "Wait for last Tx complete......" ) );
// wait for Tx Complete event
adl_eventWait ( Uart2EventHandle, UART2_TX_EVENT_WAIT_MASK, NULL,
ADL_EVENT_WAIT_ALL, ADL_EVENT_NO_TIMEOUT );
// clear TxComplete event
adl_eventClear ( Uart2EventHandle, UART2_TX_EVENT_WAIT_MASK, NULL );
TRACE ( ( UA_UART1_TRACEID, (ascii*)ptrbuff ) );
snd_buffer=ptrbuff;
// write all former read data
WriteRet = uart2_itf.write ( Uart2Handle, ptrbuff,
( UART2_MAX_DATA_SIZE - NbTbRead ) );
if ( WriteRet == CH_STATUS_ERROR )
TRACE ( ( UA_UART1_TRACEID, "ERROR write !!!!! pWriteData %x"\
"DataNbToWrite %d", \
( UART1_MAX_DATA_SIZE - NbTbRead ) ) );
else
TRACE ( ( UA_UART1_TRACEID, "ADL Write Process Returns [%d]", \
WriteRet ) );
TRACE ( ( UA_UART1_TRACEID, (ascii*) ptrbuff) );
if ( BuffFull == TRUE )
BuffFull = FALSE;
// clear RxComplete event
else
TRACE ( ( 1, "No Data Received so far" ) );
// End of while ( UA_INFINITE_LOOP_COUNTER )
And this my TCP client programm: It is a modificated program from the example
static void cbevh ( wip_event_t *ev, void *ctx )
switch ( ev->kind )
case WIP_CEV_OPEN:
TRACE ( ( NORMAL_TRACE_LEVEL, “[SAMPLE] Connection established successfully” ) );
break;
case WIP_CEV_READ:
int nread;
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Some data arrived\n" ) );
nread = wip_read ( ev->channel, rcv_buffer + rcv_offset, sizeof ( rcv_buffer ) );
if ( nread < 0 )
TRACE ( ( ERROR_TRACE_LEVEL, "[SAMPLE] read error %i", nread ) );
// wip_write ( ev->channel, rcv_buffer, sizeof ( rcv_buffer ));
return;
rcv_offset += nread;
if ( rcv_offset == sizeof ( rcv_buffer ) )
TRACE ( ( ERROR_TRACE_LEVEL, "[SAMPLE] Reception capacity exceeded, won't read more" ) );
else
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Wrote %i bytes of data from network to rcv_buffer. "
"%i bytes remain available in rcv_buffer\n", nread, sizeof ( rcv_buffer ) - rcv_offset ) );
break;
case WIP_CEV_WRITE:
int nwrite;
int i;
int a;
//while (nwrite==0)
// TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] No data available" ) );
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Can send more data" ) );
for (i=0;i<=20;i++)
nwrite=wip_write ( ev->channel, snd_buffer ,sizeof ( snd_buffer )-1);
for (a=0;a<=2000000000;a++)
TRACE ( ( 1, "%i", a ) );
TRACE ( ( 1, "%i", i ) );
if ( nwrite < 0 )
TRACE ( ( ERROR_TRACE_LEVEL, "[SAMPLE] write error %i", nwrite ) );
return;
snd_offset += nwrite;
if ( snd_offset == sizeof ( snd_buffer ) )
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Everything has been sent, won't send more." ) );
else
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Wrote %i bytes. %i bytes left to send in snd_buffer",
nwrite, sizeof ( snd_buffer ) ) );
break;
case WIP_CEV_ERROR:
TRACE ( ( ERROR_TRACE_LEVEL, "[SAMPLE] Error %i on socket. Closing.", ev->content.error.errnum ) );
wip_close ( ev->channel );
break;
case WIP_CEV_PEER_CLOSE:
TRACE ( ( NORMAL_TRACE_LEVEL, "[SAMPLE] Connection closed by peer" ) );
break;
default:
break;
It would be perfect if I can have the data in snd_buffer.
I think it is very simple but I see no trees because of the would^^
Tank you
