Strange!
I’ll post the code here:
* SerialTask2.c
* Created on: 16-07-2009
* Author: Palsson
// ADL interface global header
#include "adl_global.h"
#include "wm_uart.h"
#include "utils/ringbuf.h"
#include "Global.h"
#define UART2_PORT_TYPE ADL_AT_PORT_TYPE(ADL_AT_UART2,FALSE)
#define SERIAL2_BUFFER_SIZE 1024
adl_ioDefs_t rs485TermPin;
s32 uart2PortHandler;
u8 serial2Buffer[SERIAL2_BUFFER_SIZE];
ascii serial2WorkingBuffer[SERIAL2_BUFFER_SIZE];
tRingBufObject s2RingBufObject;
s32 dataReadyEvent;
s32 txDoneEvent;
xMessageStructure s2MsgPackage;
#define TEST_LNG 23
static const ascii* testString = "Testing RS485 Interface";
u8 rs485Testing;
adl_ctxID_e rs485TaskID;
extern u8 globalTesting;
static sUartSsIoc_t ioCtrlSend,ioCtrlRecv;
static sGItfCont_t serial2Interface;
#define RECV_ENABLE(_X_) serial2Interface.io_control( _X_, IOC_UART_SS, (void*) &ioCtrlRecv)
#define SEND_ENABLE(_X_) serial2Interface.io_control( _X_, IOC_UART_SS, (void*) &ioCtrlSend)
#define SendString(_X_) adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_AT_UART1,ADL_AT_RSP),_X_)
extern adl_ioDefs_t myIODefs[NUM_OF_GPIO];
extern s32 ioHandle;
extern s32 semaphoreRingBuf;
static void CallBack_OnTxComplete( void* user_data, psUartCbOtxC_t psOnTxParam );
static void CallBack_OnRxDataAvailable (void* user_data, void* ev_param);
/* Call-back table */
static const sGCbDesc_t uartCbTab[] =
/* user data */ /* Call-backs */
{ (void*)UART_CB_ON_TX_COMPLETE, (pGEvtNotif_t)&CallBack_OnTxComplete },
{ (void*)-1L, (pGEvtNotif_t)NULL },
{ (void*)UART_CB_ON_RX_DATA_AVAILABLE, (pGEvtNotif_t)&CallBack_OnRxDataAvailable },
/* Uart Callbacks */
static void CallBack_OnTxComplete( void* user_data, psUartCbOtxC_t psOnTxParam ){
/* set Tx event */
adl_eventSet( dataReadyEvent, TX_EVENT_WAIT_MASK );
return;
static void CallBack_OnRxDataAvailable (void* user_data, void* ev_param){
/* set Rx event */
adl_eventSet(dataReadyEvent, RX_EVENT_WAIT_MASK);
return;
u16 Serial2_CompareTestString(){
u16 ringBufLength,workerLength;
memset(serial2WorkingBuffer,0,SERIAL2_BUFFER_SIZE);
ringBufLength = RingBufUsed(&s2RingBufObject);
RingBufRead(&s2RingBufObject,(u8*)serial2WorkingBuffer,ringBufLength);
RingBufFlush(&s2RingBufObject);
serial2WorkingBuffer[ringBufLength] = 0;
workerLength = wm_strlen(serial2WorkingBuffer);
if(wm_strncmp(serial2WorkingBuffer,testString,TEST_LNG) != OK){
SendString("RS485 - ERROR String Compare\n\r");
}else{
SendString("RS485 - OK String Compare\n\r");
return workerLength;
u16 Serial2_CreateSample(){
SendString("Serial2_CreateSample\n\r");
wm_sprintf(serial2WorkingBuffer,"<sample><runningHours><00:00></runningHours><message>");
RingBufRead(&s2RingBufObject,(u8*)&serial2WorkingBuffer[workerLength],ringBufLength);
workerLength = workerLength + ringBufLength;
wm_sprintf(&serial2WorkingBuffer[workerLength],"</message></sample>");
workerLength = strlen(serial2WorkingBuffer);
void Serial2_PortHandlerStart(){
u16 sampleLength;
u16 nb_read;
ascii chr[2];
rs485TaskID = adl_ctxGetID();
for(;;){
if(rs485Testing||globalTesting){
SEND_ENABLE(uart2PortHandler);
serial2Interface.write(uart2PortHandler,(u8*)testString,TEST_LNG);
if(adl_eventWait(dataReadyEvent,TX_EVENT_WAIT_MASK,NULL,ADL_EVENT_WAIT_ANY,ADL_EVENT_NO_TIMEOUT) == OK){
adl_eventClear (dataReadyEvent, TX_EVENT_WAIT_MASK, NULL);
adl_ctxSleep(10);
RECV_ENABLE(uart2PortHandler);
if(adl_eventWait(dataReadyEvent,RX_EVENT_WAIT_MASK,NULL,ADL_EVENT_WAIT_ALL,ADL_EVENT_NO_TIMEOUT) == OK){
adl_eventClear (dataReadyEvent, RX_EVENT_WAIT_MASK, NULL);
nb_read = serial2Interface.read( uart2PortHandler, chr, 1);
while(nb_read > 0){
if(chr[0] != '\r'){
if(adl_semConsume(semaphoreRingBuf) == OK){
RingBufWriteOne(&s2RingBufObject,chr[0]);
adl_semProduce(semaphoreRingBuf);
}else{
sampleLength = Serial2_CompareTestString();
}else{
SendString("RS485 Task Suspended\n\r");
adl_ctxSuspend(rs485TaskID);
SendString("RS485 Task Resumed\n\r");
return;
s32 Serial2_OpenUartInterface(){
s32 handle;
sUartSettings_t Settings;
psGItfCont_t pinterface;
sUartEvent_t events;
sUartLc_t lc;
sUartFlowCtrl_t Fc;
/* Events */
events.user_data = (void*)0;
events.valid_cb = UART_CB_ON_RX_DATA_AVAILABLE | UART_CB_ON_TX_COMPLETE;// | UART_CB_ON_TX_EMPTY;
memcpy((u8*)events.cb_list, (u8*)uartCbTab, 6*sizeof(sGCbDesc_t));
/* Line Coding */
lc.valid_fields = UART_LC_ALL;
lc.rate = (eUartRate_t)(UART_RATE_USER_DEF | 19200 );
lc.stop = UART_STOP_BIT_1;
lc.parity = UART_PARITY_NONE;
lc.data = UART_DATALENGTH_8;
/* Device */
Settings.capabilities = NULL;
Settings.identity = "UART2";
Settings.role = UART_ROLE_NM;
Settings.event_handlers = &events;
Settings.interface = &pinterface; /* To retrieve the UART SP Interface */
Settings.line_coding = &lc;
handle = adl_OpenDevice( DF_UART_CLID, &Settings );
if( !handle ){
adl_atSendResponse(ADL_AT_RSP, "\r\nError\r\n");
// UART2 opening failed...
return (s32)NULL;
/* Locally store the uart interface */
serial2Interface = *pinterface;
/* Flow control IO control setting */
Fc.op = G_IOC_OP_SET;
Fc.type = UART_FC_RTS_CTS;
if( serial2Interface.io_control( handle, IOC_UART_FC, (void*) &Fc) ){
serial2Interface.close( handle );
adl_atSendResponse(ADL_AT_RSP, (char*)"ERROR : IOCTL FC Set\n\r" );
handle = 0;
return (s32)NULL;
/* Initiate control variables */
ioCtrlRecv.op = G_IOC_OP_SET;
ioCtrlRecv.sig_id = UART_SIG_RTS;
ioCtrlRecv.state = UART_SIG_RTS;
ioCtrlSend.op = G_IOC_OP_SET;
ioCtrlSend.sig_id = UART_SIG_RTS;
ioCtrlSend.state = 0;
//Set device ready for receiving data
if(RECV_ENABLE(handle)){
adl_atSendResponse(ADL_AT_RSP, (char*)"ERROR : IOCTL Set RTS\n\r" );
handle = 0;
return (s32)NULL;
while(1){
// ioCtrlRecv.op = G_IOC_OP_SET;
// ioCtrlRecv.sig_id = UART_SIG_RTS;
// ioCtrlRecv.state = 0;
// if( serial2Interface.io_control( handle, IOC_UART_SS, (void*) &ioCtrlRecv) ){
// adl_atSendResponse(ADL_AT_RSP, (char*)"ERROR : IOCTL Set CTS\n\r" );
// handle = 0;
adl_ctxSleep(10);
SEND_ENABLE(handle);
adl_ctxSleep(10);
// ioCtrlSend.op = G_IOC_OP_SET;
// ioCtrlSend.sig_id = UART_SIG_RTS;
// ioCtrlSend.state = UART_SIG_RTS;
// if( serial2Interface.io_control( handle, IOC_UART_SS, (void*) &ioCtrlSend) ){
// adl_atSendResponse(ADL_AT_RSP, (char*)"ERROR : IOCTL Set RTS\n\r" );
// handle = 0;
RECV_ENABLE(handle);
return handle;
void SerialTask2(void){
SendString("[Serial Task 2] Multitasking\n\r");
rs485TermPin = myIODefs[RS485_TERM];
//Activate RS485 Termination
adl_ioWriteSingle(ioHandle,&rs485TermPin,TRUE);
RingBufInit(&s2RingBufObject,serial2Buffer,SERIAL2_BUFFER_SIZE);
dataReadyEvent = adl_eventCreate(INIT_TX_RX_MASK);
//txDoneEvent = adl_eventCreate(0);
uart2PortHandler = Serial2_OpenUartInterface();
Serial2_PortHandlerStart();
