I have a UART terminal device that had flow control aspect to it.
My logic from PC works great and reads from terminal device just fine. Same logic from FASTRACK Supreme is becoming a slave device (request shows up as response). What Can I do to make the AT application UART master sending out requests. I know it is around CTS/RTS setting. I would appreciate the help.
s32 handle;
sUartSettings_t Settings;
psGItfCont_t pinterface;
sUartEvent_t events;
sUartLc_t lc;
sUartFlowCtrl_t Fc;
TRACE (( 1, "uart_open(UART%c,%d)",identity[4], speed ));
/* Device */
Settings.capabilities = NULL;
Settings.identity = identity;
Settings.role = UART_ROLE_DCE;
/* Events */
events.user_data = (void*)0;
events.valid_cb = UART_CB_ON_ALL;
memcpy((u8*)events.cb_list, (u8*)uartCbTab, 6*sizeof(sGCbDesc_t));
Settings.event_handlers = &events;
/* To retrieve the UART SP Interface */
Settings.interface = &pinterface;
/* Line Coding */
lc.valid_fields = UART_LC_ALL;
lc.rate = (eUartRate_t)(UART_RATE_USER_DEF | 2400 );
lc.stop = UART_STOP_BIT_1;
lc.parity = UART_PARITY_EVEN;
lc.data = UART_DATALENGTH_7;
Settings.line_coding = &lc;
/* open UART device */
if( 0 < (handle = adl_OpenDevice( DF_UART_CLID, &Settings)) )
TRACE(( 1, "UART successfully opened" ));
/* Locally store the uart interface */
uart_itf = *pinterface;
/* Flow control IO control setting */
Fc.op = G_IOC_OP_SET;
//Fc.type = UART_FC_RTS_CTS;
Fc.type = UART_FC_NONE;
if( uart_itf.io_control( handle, IOC_UART_FC, (void*) &Fc) )
uart_itf.close( handle );
TRACE((1, "ERROR : IOCTL FC Set"));
handle = 0;
sUartSsIoc_t sigSetting;
sigSetting.op = G_IOC_OP_SET;
sigSetting.sig_id = UART_SIG_CTS;
sigSetting.state = UART_SIG_CTS;
if( uart_itf.io_control( handle, IOC_UART_SS, (void*) &sigSetting) ) {
TRACE((1, "ERROR : IOCTL CTS Set"));
else
TRACE(( 1, "Uart_Open : ERROR UART is not opened" ));
return handle;
I get following errors and data is not being transmitted from FASTRACK to my terminal device:
10/01/29,02:43:10:140 LLH 1 EVENT : SIG CHANGE delta 4 state 0
Haiden
