Tx Control line command issues error
Using EM7411 verify Output Power Level for TDD Band 48 and get error to the TXCONTROL entry. Using command line below. Thank you Jerry
ati
Model: EM7411
Revision: SWI9X50C_01.14.03.00 b06bd3 jenkins 2020/09/23 10:53:35
IMEI: 350734570144121
IMEI SV: 13
FSN: 8F3071202804B1
+GCAP: +CGSM
AT!ENTERCND=“XXXX”
AT!DAFTMACT
290300
AT!DARCONFIG=0,3,48,55990,2
AT!DALTXCONTROL=0,1,10,1,0,1,12,19
ERROR
Hi @jelyons
Welcome you to our community
In order to troubleshoot your issue, could you please share with me some information as below:
  1. Has this issue happened before? Or is this the first time?
  2. Is this issue happens only with band 48 or all bands?
  3. Please upgrade to latest firmware for your EM7411 module following the link below, then recheck if the issue still happens in this case
    https://source.sierrawireless.com/resources/airprime/minicard/74xx/em_mc74x1-approved-fw-packages/#sthash.APuxuxIs.dpbs
  4. You can refer to Section C - Testing on page 72 in the link below for the test procedure
    AirPrime - EM7411 - Product Technical Specification
Jerdung,
Yes followed the steps on Page 72 see attached .txt. Looking into the firmware on our side and what is available to update with . It looks like the “AT!DALTXCONTROL” wasn’t introduced yet for the current firmware I have on the EM7411.
Jerry
Using AT Commands_ Error.txt (732 Bytes)
Hi @jelyons
I see that you are using old Release 16 so please upgrade to Release 20 which I provided in previous comment then recheck if the issue is resolved in this case.
