Following post provides a TCP server listening on IP 192.168.14.31 (USB IP of the Airlink device), port 56789.
In case you want to access the TCP server from the WAN interface, you must in AceManager set a port forwarding rule. In Security tab, Port Forwarding menu, set the host IP and port to the IP and port specified in the socket.bind API
local sched = require "sched" -- Lua scheduling and synchronization lib.
-- Beware to call it before the socket lib otherwise socket will not connect
local socket = require "socket"
function main ()
local server = assert(socket.bind("192.168.14.31", 56789))
print("inside main")
while true
do
-- wait for a connection from any client
local client = server:accept()
-- make sure we don't block waiting for this client's line
client:settimeout(10)
while true do
-- receive the line
-- there are 3 methods to receive data:
-- "*l", to receive line by line (beware that the client must send the line feed character! if you are using a TCP client tool, do check the "LineFeed" box if any)
-- n, to specify a number of bytes to read out from the socket
-- "*a", to read all the data on the fly
local line, err = client:receive("*l")
-- if there was no error, send it back to the client
if not err then
print("received data:", line)
-- client:send(line .. "\n") end
client:send("this is the answer from my AAF TCP server")
else print(err)
if err == "closed" then
client:close()
break
end
end
end
end
end
-- Schedule the main function, and launch the scheduler main loop
sched.run(main)
sched.loop()
