Suite 2.35.5 Windows 7 64-bit crash on start
I’ve just downloaded the Suite 2.35.5 Full Installer, the install proceeded without errors, but when I start the Development Studio I get “An error has occurred. Please see the log file …”.
The log file says:
!SESSION 2013-02-05 16:04:25.983 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_33
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86 -data @noDefault
!ENTRY com.swi.tm.core 4 0 2013-02-05 16:04:28.362
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle “com.swi.tm.core_1.4.0.201212051531-R10773 [19]” could not be resolved. Reason: Missing Constraint: Require-Bundle: org.apache.commons.io; bundle-version=“1.4.0”
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY com.swi.tm.core 4 0 2013-02-05 16:04:29.293
!STACK 0
at org.eclipse.osgi.framework.internal.core.StartLevelManager.setBundleSL(StartLevelManager.java:670)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:435)
I have Java RE 6 32-bit installed, but also 1.7 64-bit and eclipse 4.2 installed (in another folder, for android development).
Anyone else had this issue?
Mark
Just done a clean install on a Windows XP machine with jre_6u34 installed and nothing else and get the same error.
There is some troubles with former installers.
You should grab the latest full/light installer; or if you want to keep the 2.35.5 version scope, in the full installer select the “Install from this package” option, in order to install just this version, and not the latest one coming from the update site (default behavior).
