there are two source code text bellow. the first one is subscribed successfully, but the second one is error and returns “ADL_RET_ERR_PARAM”, I don’t know why .could anyone give a exaplaination?
example 1.
//when input "AT+FLASH+S", the SubFlash is called, then it returns
//" Input String is:at+flash=s"
//"SubFlash: ADL_RET_ERR_PARAM"
static adl_atCmdPreParser_t Cmd;//adl_atCmdPreParser structure
char* FlashHdl;//The Handle of the set of objects to subscribe to
/* This function subscribes to a set of objects identified */
/* Input: NbObjectRes The number of objects related to the given handle. I */
void SubFlash(u16 NbObjectsRes)
s8 FlashRe;
FlashRe = adl_flhSubscribe ( FlashHdl, NbObjectsRes);
//print the debug information to UART1
switch (FlashRe)
case OK:
adl_atSendResponse ( ADL_AT_UNS,"\r\n SubFlash: OK\r\n" );
break;
case ADL_RET_ERR_PARAM:
adl_atSendResponse ( ADL_AT_UNS,"\r\n SubFlash: ADL_RET_ERR_PARAM\r\n" );
break;
case ADL_RET_ERR_ALREADY_SUBSCRIBED:
adl_atSendResponse ( ADL_AT_UNS,"\r\n SubFlash: ADL_RET_ERR_ALREADY_SUBSCRIBED\r\n" );
break;
case ADL_FLH_RET_ERR_NO_ENOUGH_IDS:
adl_atSendResponse ( ADL_AT_UNS,"\r\n SubFlash: ADL_FLH_RET_ERR_NO_ENOUGH_IDS\r\n" );
break;
case ADL_RET_ERR_SERVICE_LOCKED:
adl_atSendResponse ( ADL_AT_UNS,"\r\n SubFlash: ADL_RET_ERR_SERVICE_LOCKED\r\n" );
break;
void CmdFlashhdl( adl_atCmdPreParser_t *Cmd )
char cmdbuf[100];
//output the reveived command to UART1.
wm_memcpy(cmdbuf,Cmd->StrData,Cmd->StrLength);
cmdbuf[Cmd->StrLength]=0;
adl_atSendResponse ( ADL_AT_UNS,"\r\n Input String is:" );
adl_atSendResponse ( ADL_AT_UNS,cmdbuf );
//check the command, if the command is "AT+FLASH=S" then call SubFlash.
switch (cmdbuf[9])
case 'S'://subscribe the flash area
case 's':
SubFlash(5);
break;
default:
adl_atSendResponse ( ADL_AT_UNS,"\r\n Cmd ERROR \r\n" );
TRACE (( 1, "Embedded Application : Main" ));
//subscribe the "AT+FALSH=" command from UART1.
adl_atCmdSubscribe ( "AT+FLASH=", CmdFlashhdl, ADL_CMD_TYPE_ROOT);
adl_atSendResponse ( ADL_AT_UNS, "\r\nStart get the information of Ram and Flash!\r\n" );
example 2
//"SubFlash: OK"
// that is waht I want.
s8 FlashRe;
switch (FlashRe)
case OK:
break;
break;
break;
break;
break;
//call SubFlash
SubFlash(5);
