Start GPRS bearer problem
Dear all ,
The GPRS bearer cannot start ,it gives WIP_BEV_CONN_FAILED event
I donot know why ?
I give a correct APN , and all setting donot return errors
put when i make AT command to start the bearer it started well .
I am using multitasking ,
my module is Q2687
Iam waiting your help
thanks alot
Make sure you are opening the bearer on your highest priority thread, otherwise it will not work.
Thanks for you reply
When I put opening the bearer in main task then i set options and start the bearer in the other task
it works sometimes and sometimes not
what is the problem now ?
