what do you see now?
didn’t it ask you to type log in name and password?
Yeah I was able to see so logs which and the login was overridden by these logs
then are you able to login and type command there?
I have tested with an ok device It doens’t have any overridden logs but the password is shown incorrect
then you should enter the correct password, otherwise you cannot go into console to enter commands
At what stage is the password set for UART2 ? And is’nt ssh password and UART2 password same ?
i don’t know how is your device configured, especially the password…
You should ask the vendor
okk I will contact the vendor about the password then
I have the same issue on my WP7702, I can’t have Root SSH access on the FX30.
It gives me the same error
(lsh:SWI-FX30-CATM) xxx@xxx:~/newWorkspace$ ssh root@192.168.2.2
ssh: connect to host 192.168.2.2 port 22: Connection refused
I can enter in AT!BOOTHOLD then have USB acces for re flash the firmwareWP77xx_Release15.1_SIERRA.spk
The reflash been with FTD2 on windows is successfull but same result -->refused access port 22
The reflash been with swiflash lasts longtime never finish.
(I updated the swiflash)
–>same result
I can also see on
AT!IMAGE?
FW 1 EMPTY 0 0 0
FW 2 GOOD 2 0 0 ?_? 02.36.08.09_?
FW 3 GOOD 1 0 0 001.049_000 02.36.08.09_SIERRA
Max FW images: 3
Active FW image is at slot 2
PRI FF GOOD 0 0 0 001.067_005 02.36.06.00_ATT
PRI FF GOOD 0 0 0 001.079_000 02.36.08.09_GENERIC
PRI FF GOOD 0 0 0 001.049_000 02.36.08.09_SIERRA
PRI FF GOOD 0 0 0 001.059_001 02.36.08.01_TELSTRA
PRI FF GOOD 0 0 0 001.042_004 02.22.12.00_VERIZON
Max PRI images: 50
I also made hard reboot with 10s maintaining on reset on boot.
→ same result
I changed the dropbear file and I think the issu is due to that.
But when reflash the FW, we should have factory state and new default dropbear no?
Can someone help me or share the topic resolved please?
what is the return of AT!PARTITION=?
Are you able to downgrade to R11 and run swiflash to erase the userapp partition?
hi @jyijyi
Why this ssh Connection refuse issue occures ?? can i know the reason for this??
Mnau
maybe it has set up some SSH key, if you don’t have the correct key, you will be refused to login
BTW, is this PC problem?
Is this happening to one module only?
does it work in Windows PC with tera term SSH connection?
What firmware is using in this module?
are you able to erase the userapp partition in UART console and see if the SSH is OK afterwards?
