Hi all,
I am trying to work with SPI on OpenAT v6.11 for the Quick Q2686 module and, although the sample code compiles OK, when I’m uploading and running it on the module, I get an error message ADL_RET_ERR_NOT_SUPPORTED when I’m trying to subscribe to the SPI service:
adl_busSPISettings_t SPIConfig =
5, // Clk_Speed (2 MHz)
ADL_BUS_SPI_CLK_MODE_0, // Mode 0: rest state 0, data valid on rising edge
ADL_BUS_SPI_ADDR_CS_HARD, // Use dedicated pin to handle the Chip Select signal
ADL_BUS_SPI_CS_POL_LOW, // Chip Select active in low state
ADL_BUS_SPI_MSB_FIRST, // Data are sent MSB first
0, // No GPIO used to handle the Chip Select signal
ADL_BUS_SPI_FRAME_HANDLING, // LOAD signal not used
ADL_BUS_SPI_DATA_BIDIR, // 2 Wires configuration
ADL_BUS_SPI_MASTER_MODE, // Master mode
ADL_BUS_SPI_BUSY_UNUSED // BUSY signal not used
// BUS Handles
s32 SPIHandle;
s32 Result;
s32 SPIerror;
void InitSPI(void)
// Subscribe to the SPI1 BUS
Result = adl_busSubscribe ( ADL_BUS_ID_SPI, 1, &SPIConfig );
if (Result >= 0) {
SPIerror = OK;
SPIHandle = Result; // Success
else {
SPIerror = Result;
Any help will be highly appreciated.
P.S. In the Q2686_PTS_revision7.pdf document on page 20 is stated that the OS 6.60 does not drive the serial interface. Instead, the version 4 does. If that’s the case, does anyone know how could I download the latest OpenAT V4?
