Yes.
An AT command would do - but see: New Features - Complete API
See also: AT+WMFM - Inconsistent (and unhelpful) Behaviour
Quite possibly - just a note to make sure it doesn’t regress…
Yes.
I often have COM1 as my serial port input in DATA mode, COM3 via USB for trace output. With target manager I can’t get the serial port (COM1) to open (probably as there is no reply). I have to log in via hyperterminal, enter +++ and then Target Managment can talk to it and download code etc.
Also if this connection fails, the Setting still thinks its connected so you can’t switch back to COM3. It would be useful if the different COM settings stored its own set of preferences, as my COM1 and COM3 will usually have different baud rates.
This may be a little late as you have already released something!
Please have a try with the 1.2.0 alpha version released few days ago. I think it should be OK for settings persistence on different ports. Please note that with this version, you’ll be able to connect to both ports at the same time. But note also that “data mode” handling is not perfect in this alpha.
Now fixed: Smilies broken! - #3 by awneil ![]()
