Hi All,
I have SNMP working using the local Ethernet port on my modem (using Q2686RD).
Will the API only work with a local Ethernet port, or can I somehow interrogate the modem using SNMP over its public WAN IP address?
Thanks.
Hi All,
Thanks.
There is no such limitation that the SNMP API’s cannot be used other than the local ethernet port. You can use public WAN IP provided there is no firewall.
Thanks for the answer, Rex_alex
