Hi
There seems to be a latency issue with the SL8082T SPI bus service OAT library
The attached file is an example I captured on the SL8 SPI port - using the SPI sample (either sync or async methods have same issue).
with command at+read=FFFF,32  // no address with a byte opcode write followed by 32 byte read
[attachment=0]SL8082T SPI CS to CS.png[/attachment]
[attachment=1]SL8082T SPI 1 byte opcode and 32byte read .png[/attachment]
The clock speed is ~16MHz
The CE is low for 0.377ms
Between the write end and the read start is a delay of 0.198ms
Between the read finish and chip select high there is a delay of 0.15ms
I modified the sample to send multiple reads - one after the other. There is a 1.16ms delay between the 1st CS high and the next 2nd CS low.
These are very long delays
- why is this?
- is there anything I can do to reduce them?
The inter-byte read delay is low <0.16us
Thanks in advance
John
