Hello, i use sl8082 for tcpip connection to server. If i try to send frames with 0x7d or 0x7e symbols, server don’t receive its. All frames without these symbols reached the server.
Which FW version are you using?
Also what server are you using?
Alex
i updated fw to 752.2 A5 20141128. Server is “CurrPorts” program.
Hi Denisl,
May I ask how you send the data?
Are you using UDP or TCP protocol? And thru WIP or dialup connection?
Please also share the WIP version (if used) and test sequence so I can test further.
I tried using WIP UDP and no issue sending 0x7D 0x7E.
Thx
