Simultaneous Audio and Datastream BC118
Dear,
Is it possible to set up a simultaneous audio and data stream with the BC118? The BC127 can do this (but needs to overcome UART sync issue between audio and data streams). I suppose the same capabilities and issue with the BC118 compared to the BC127. Is this assumption correct?
Regards,
Wim
Wim,
BC118 is a BLE only device, it cannot do audio.
What are the synch issues with the BC127?
Hi Matt,
I mean the following with sync issues:
the issue I see if you want to stream data and audio at the same time. this means quickly switching between BT Classic mode for audio, and BLE for data. The UART itself does not have a mechanism to do this.
Regards,
Wim
If auto routing between the interfaces is on then it will obviously route the audio as it sees fit but yes if you want to stream data in on line data mode then you do need to dip in and out of command/data mode to send commands.
