I am having difficulty relating API wip_getFile() to it’s corresponding at commands +wipcreate and +wipdata. I understand HTTP and can easily retrieve data from a web host either manually through hyperterm or by at commands in an app. I can’t seem to do the same with the HTTP API’s…
I want to send this simple GET method to google home page, as I have done on hyperterm…
at+wipcfg=1
at+wipbr=1,6
at+wipbr=2,6,11,“orbcomm.t-mobile.com”
at+wipbr=4,6,0
+CGREG: 5,“23A0”,“DC3B”
+WIND: 15,3,"-32",4,“11/11/18,21:22:30-32”,6,“0”
at+wipcreate=2,1,“www.google.com”,80
+WIPREADY: 2,1
at+wipdata=2,1,1
CONNECT
[b]GET / HTTP/1.1
Host: google.com
Connection: keep-alive[/b]
HTTP/1.1 200 OK
Date: Fri, 18 Nov 2011 21:23:40 GMT
… google data
… by using the wip_getFile. Now I have based my code on the http ex. in the Open AT tutorial book. When I run the app the bearer initializes fine but return value from wip_getFileOpts is always NULL indicating error. I have included both message headers and specified the GET method.
Can anyone see where I am going wrong?
#include "adl_global.h"
#include "wip_net.h"
#include "wip_bearer.h"
#include "wip_http.h"
#include "adl_at.h"
#include "generated.h"
const u16 wm_apmCustomStackSize = 4096;
//APN settings
#define gprs_apn "orbcomm.t-mobile.com"
#define gprs_login ""
#define gprs_passw ""
//HTTP settings
ascii *HTTP_HOSTNAME = "www.google.com";
ascii *HTTP_URLNAME = "www.google.com";
//Other variables
wip_bearer_t bearerHandle = NULL;
wip_channel_t httpCnxCh = NULL;
wip_channel_t httpDataCh = NULL;
adl_tmr_t *timer_ptr;
u32 timeout_period = 5;
//Function definitions
void sim_handler(u8 Event);
void evh_bearer(wip_bearer_t b, s8 event, void *ctx);
void timer_handler(u8 Id, void *context);
void httpData_handler(wip_event_t *ev, void *ctx);
adl_atSendResponse(ADL_AT_UNS,"Inside httpData_handler\r\n");
switch(ev->kind)
case WIP_CEV_OPEN:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler open\r\n");
break;
case WIP_CEV_READ:
u8 buf[256];
wm_memset(buf,0,256);
//Collect reponse from server
adl_atSendResponse(ADL_AT_UNS,"httpData_handler read\r\n");
while (wip_read(httpDataCh, buf, 256) > 0)
adl_atSendResponse(ADL_AT_UNS,"Reading data...\r\n");
break;
case WIP_CEV_WRITE:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler write\r\n");
break;
case WIP_CEV_PEER_CLOSE:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler peer closed\r\n");
wip_close(httpDataCh);
wip_close(httpCnxCh);
break;
case WIP_CEV_ERROR:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler error\r\n");
break;
case WIP_CEV_PING:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler ping\r\n");
break;
case WIP_CEV_DONE:
adl_atSendResponse(ADL_AT_UNS,"httpData_handler done\r\n");
break;
adl_atSendResponse(ADL_AT_UNS,"\r\nInside timer_handler\r\n");
//Start HTTP data session
httpDataCh = wip_getFileOpts (httpCnxCh,
HTTP_URLNAME,
(wip_eventHandler_f) httpData_handler,
NULL,
WIP_COPT_HTTP_METHOD, WIP_HTTP_METHOD_GET,
WIP_COPT_HTTP_HEADER, "Host", HTTP_HOSTNAME,
WIP_COPT_HTTP_HEADER, "Connection", "keep-alive",
WIP_COPT_END);
if (httpDataCh == NULL)
adl_atSendResponse(ADL_AT_UNS,"wip_getFileOpts error occurred!!\r\n");
switch(event)
case WIP_BEV_IP_CONNECTED:
adl_atSendResponse(ADL_AT_UNS,"\r\nevh_bearer connected\r\n");
//Start HTTP session
httpCnxCh = wip_HTTPClientCreate(NULL, NULL);
if (httpCnxCh == NULL)
adl_atSendResponse(ADL_AT_UNS,"wip_HTTPClientCreate error occurred!!\r\n");
timer_ptr = (adl_tmr_t*) adl_tmrSubscribe(FALSE, timeout_period, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t) timer_handler);
break;
case WIP_BEV_CONN_FAILED:
adl_atSendResponse(ADL_AT_UNS,"\r\nevh_bearer connection failed\r\n");
wip_bearerClose(bearerHandle);
break;
case WIP_BEV_STOPPED:
adl_atSendResponse(ADL_AT_UNS,"r\nevh_bearer connection stopped\r\n");
break;
default:
adl_atSendResponse(ADL_AT_UNS,"r\nevh_bearer actions unknown\r\n");
break;
if (ADL_SIM_EVENT_FULL_INIT == Event)
s8 ret;
ascii retStr[30];
//Open the GPRS bearer
ret = wip_bearerOpen(&bearerHandle, "GPRS", (wip_bearerHandler_f) evh_bearer, NULL);
wm_itoa(ret, retStr);
adl_atSendResponse(ADL_AT_UNS,"\r\nReturn of wip_bearerOpen: ");
adl_atSendResponse(ADL_AT_UNS,retStr);
ret = wip_bearerSetOpts(bearerHandle, WIP_BOPT_GPRS_APN, gprs_apn, WIP_BOPT_LOGIN, gprs_login, WIP_BOPT_PASSWORD, gprs_passw, WIP_BOPT_END);
adl_atSendResponse(ADL_AT_UNS,"\r\nReturn of wip_bearerSetOpts: ");
ret = wip_bearerStart(bearerHandle);
void main_task(adl_InitType_e InitType)
adl_atSendResponse(ADL_AT_UNS,"Program started...\r\n");
adl_simSubscribe((adl_simHdlr_f) sim_handler, NULL);
wip_netInit();
