simaltaneous AT commands execution in CMUX mode
In CMUX mode, can AT commands be executed simultaneously for a particular software element?
If an AT command is in progress on one port, the port is blocked until the response is not received. Same holds true in CMUX mode also. If a command is issued for a particular software element (for example WIPSoft), other AT commands from a different port for the same software element will not be executed until the response for the first command is received.
