just type “AT” in COM4 and see if it returns OK
Returned ok
actually what do you want now?
didn’t you already have the modem port COM4 for AT command communication?
AT Port and additional ports used to be present under “ports” rather than using the modem port for AT. Just checking to see if that is possible ?
no, i don’t think so
I also use the COM port in modem port
It has no harm to your use case, right?
I’ll test. Thank you.
Hi jyiJyi<
I am trying to apply a new firmware : FX30_WP77xx_full_R9.1.1.013-sierra
I have the .cwe file downloaded. How do i apply this ?
Hi JyiJyi,
Do you know the path directory for the FX30 file system ? struggling to find where to copy the file
normally i will just copy to /tmp of module and then upgrade by “fwupdate download /tmp/xxx.cwe”
Got it. thank you. Working now
