In the GPIO, adl_ioSubscribe function,
there is a polling time Parameter, if that parameter is zero, then it goes to that Handler at that instant, otherwise after the polling time is complete, it goes to that Handler.
i.e, it depends on the polling time which you specify in theadl_ioSubscribe function
The ADL User Guide for v3.03 says that the Handler must be NULL if there is no polling; ie there is no handler if there is no polling - the handler is for polled inputs only.
Are you reading a different revision of the Guide? Has it changed?
The ADL User Guide for v3.03 says that it only goes to the handler when a polled input changes.
So the handler should never be called if the polled input never changes.
But my handler is called immediately after the successful subscribe irrespective of the input state and irrespective of whether it’s changed.
As I said, this behaviour does make sense for my Application; it’s just that it isn’t clearly specified - - so I just want it confirmed.
