Hello!
I have a problem with GPIO handler.
It works only once?!
I use GPIO24 as input.
Here is my code:
[b]#define GPIO_COUNT_AC 1
const adl_ioConfig_t MyGpioConfig[GPIO_COUNT_AC]=
{{ADL_IO_Q2686_GPIO_24, 0, ADL_IO_INPUT}};
//Event handle
s32 MyGpioEventHandle;
//Gpio handles
s32 MyGpioHandle;
s32 MyGpioHandle2;
//Gpio event handler
void MyGpioEventHandler(s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param)
switch(Event)
case ADL_IO_EVENT_INPUT_CHANGED:
adl_atSendResponsePort(ADL_AT_RSP, ADL_PORT_UART1, “\r\n+INPUT CHANGE\r\n”);
((adl_ioRead_t *)Param)[0].eLabel;
((adl_ioRead_t *)Param)[0].eState;
adl_ioReadSingle(GpioHandle, ADL_IO_Q2686_GPIO_24);
break;
//Main function
//Subscribe to GPIO event service
MyGpioEventHandle=adl_ioEventSubscribe(MyGpioEventHandler);
MyGpioHandle2=adl_ioSubscribe(GPIO_COUNT_AC, MyGpioConfig, ADL_TMR_TYPE_100MS, 1, MyGpioEventHandle);[/b]
Thank you!
biter
April 16, 2008, 12:56pm
2
i have the same problem .
biter
April 16, 2008, 1:58pm
3
ok it works.i read bad label.
Aghil
September 10, 2008, 6:40am
4
hi, the code shown below is getting terminated while running in RTE mode…
in target mode its not going to the handler itself.
is there anything wrong in this code.
#include “adl_global.h”
const u16 wm_apmCustomStackSize = 1024;
// Gpio Event Handle
// Gpio Handles
s32 MyGpioHandle1;
u8 ReadValue;
u32 My_Gpio_Label1 [ 1 ] = { 30 };
adl_ioDefs_t MyGpioConfig1[1] = { ADL_IO_GPIO | 30 | ADL_IO_DIR_IN | ADL_IO_LEV_HIGH };
void MyGpioEventHandler ( s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param )
TRACE (( 1, " In MyGpioEventHandler" ));
switch ( Event )
case ADL_IO_EVENT_INPUT_CHANGED :
TRACE (( 1, “ADL_IO_EVENT_INPUT_CHANGED” ));
ReadValue = adl_ioReadSingle (MyGpioHandle1, ADL_IO_GPIO | My_Gpio_Label1 [ 0 ] );
TRACE (( 1, “%d”, ReadValue));
//ReadValue = adl_ioRead (MyGpioHandle1, 1, ADL_IO_GPIO | 30 | ADL_IO_LEV_HIGH );
//TRACE (( 1, “%d”, ReadValue));
break;
TRACE (( 1, “Embedded Application : Main” ));
MyGpioEventHandle = adl_ioEventSubscribe( MyGpioEventHandler );
MyGpioHandle1 = adl_ioSubscribe ( 1, MyGpioConfig1, ADL_TMR_TYPE_100MS, 1, MyGpioEventHandle );
thank you
Aghil
Aghil
September 10, 2008, 9:47am
5
hi,
in the eg program in adl_gpio.h there is a mistake, in adl_ioReadSingle func.
its given as adl_ioReadSingle (MyGpioHandle1, ADL_IO_GPIO | My_Gpio_Label1 [ 1 ] );
but the 2nd argument is a pointer, this will u error.
Instead use this,
// In the MyGpioEventHandler
adl_ioReadSingle (MyGpioHandle1, &MyGpioConfig1 );
This will definetly work fine.
Thank You
Aghil
