Setting up EM9291 Module
I have been looking for documentation on how to set up and use the EM9291 module with a host device, such as a Raspberry Pi.
Do we have any documents outlining the steps to set up, configure, and test the EM9291 module via the USB interface?
Additionally, could you please provide the details of the Linux 6.6.36 drivers and firmware required for this module?
Arti
You can see here
You can download the mbpl usb driver here
Thanks for the prompt response.
As mentioned, my module is EM9291. Will the same steps work for this module also?
Also, my host is ARM64 architecture.
From where can I get the lite-qmi-connection-manager binary for my host?
I will need the source code to build it for my host.
the method of installation of USB driver is the same
For the source code of connection manager, please download MBPL_SDK_R44_ENG5-lite.bin.tar
Hi @jyijyi ,
I followed the steps you mentioned in the document. but I m getting:
AT!GSTATUS?
ERROR
AT+CGDCONT
AT!SCACT=1,1
ERROR
I am also not getting any ip on wwan0 device.
can you please suggest if I am missing anything.
what are the return of the followings?
ati3
AT!ENTERCND="A710"
AT!SKU?
at!IMPREF?
AT!selrat?
at!SDPREF?
At+cpin?
At+cfun?
At!pcinfo?
at!band?
at!band=?
Hi @jyijyi ,
I have conected my EM9291 module to the raspberry pi board and it is workig by default without any code change.
The driver used is : cdc_mbim
[ 423.940703] usbcore: registered new interface driver cdc_mbim
[ 425.716250] cdc_mbim 1-1.3:1.0: setting rx_max = 16384
[ 425.716635] cdc_mbim 1-1.3:1.0: cdc-wdm0: USB WDM device
[ 425.716994] cdc_mbim 1-1.3:1.0 wwan0: register ‘cdc_mbim’ at usb-0000:01:00.0-1.3, CDC MBIM, 1a:8d:7f:a6:f3:ec
But the driver here Mobile Broadband Package for Linux (SDK, Drivers, Documentation)
uses : qmi_wwan
If I use qmi_wwan driver in raspberry pi, my moduele is not working.
Can you please suggest which driver we need to use for the EM9291 module?
Arti
qmi_wwan is for RMNET driver
You need to check whether AT!USBCOMP? is using RMNET or MBIM.
But please note that rmnet is not quite recommended for users for EM9 module, MBIM is more preferred:
Hi @jyijyi ,
please find the output of the commands you asked for:
ati3
Model: EM9291
Revision: SWIX65C_02.15.01.00 5268b2 jenkins 2023/11/17 22:12:47
IMEI: 358186652504866
IMEI SV: 2
FSN: 835212742102B1
+GCAP: +CGSM
AT!SKU?
!SKU: 1105097
at!IMPREF?
!IMPREF:
preferred fw version: 02.15.01.00
preferred config name: GENERIC_030.054_001
preferred subpri index: 000
current fw version: 02.15.01.00
current carrier name: GENERIC
current config name: GENERIC_030.054_001
current subpri index: 000
AT!selrat?
!SELRAT: 00, Automatic
at!SDPREF?
RATs : WCDMA,LTE,NR5G
GWC : B1,B2,B4,B5,B6,B8,B19
LTE : B1,B2,B3,B4,B5,B7,B8,B12,B13,B14,B17,B18,B19,B20,B25,B26,B28,B29,B30,B32,B34,B38,B39,B40,B41,B42,B43,B46,B48,B66,B71
TDS :
NRSA : n1,n2,n3,n5,n7,n8,n12,n13,n14,n18,n20,n25,n26,n28,n29,n30,n38,n40,n41,n48,n66,n70,n71,n75,n76,n77,n78,n79
NRNSA: n1,n2,n3,n5,n7,n8,n12,n13,n14,n18,n20,n25,n26,n28,n29,n30,n38,n40,n41,n48,n66,n70,n71,n75,n76,n77,n78,n79
At!pcinfo?
State: Online
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, NVCRIT:0, RFCAL:0, MMWCAL:0, RFC_INIT:0
LPM persistence - None
at!band?
Index, Name
00, All bands,
0 - GW: 100200000EC00000
1 - LTE: 0000A7E2BB0F38DF 0000000000000042
3 - NRNSA: 000081A03B0A38D7 0000000000007C62
4 - NRSA: 000081A03B0A38D7 0000000000007C62
AT!USBCOMP?
Config Index: 1
Config Type: 4 (MBIM V2)
Interface bitmask: 00001009 (diag,modem,mbim)
I am working on my custom board based on imx8mp and getting hte below error when trying to run ifconfig wwan0 up.
[ 185.057509] NETDEV WATCHDOG: wwan2 (cdc_mbim): transmit queue 0 timed out 10016 ms
[ 185.065164] WARNING: CPU: 1 PID: 0 at net/sched/sch_generic.c:525 dev_watchdog+0x234/0x23c
Please note I am using cdc_mbim driver only.
thanks
it is using MBIM interface.
Is it OK now to set up mbim-network for data establishment?
Hi @jyijyi
Yes I am using mbim only but getting error.
root@imx8mp:~# dmesg | grep -i cdc
[ 1.809915] usbcore: registered new interface driver cdc_ether
[ 1.821743] usbcore: registered new interface driver cdc_ncm
[ 1.827440] usbcore: registered new interface driver cdc_mbim
[ 1.860510] usbcore: registered new interface driver cdc_wdm
[ 6.122283] cdc_mbim 1-1:1.0: setting rx_max = 16384
[ 6.129117] cdc_mbim 1-1:1.0: cdc-wdm0: USB WDM device
[ 6.142812] cdc_mbim 1-1:1.0 wwan2: register ‘cdc_mbim’ at usb-xhci-hcd.1.auto-1, CDC MBIM, d2:4b:53:20:5a:4d
[ 1145.626121] cdc_mbim 1-1:1.0 wwan2: unregister ‘cdc_mbim’ usb-xhci-hcd.1.auto-1, CDC MBIM
[ 1159.075417] cdc_mbim 1-1:1.0: setting rx_max = 16384
[ 1159.080957] cdc_mbim 1-1:1.0: cdc-wdm0: USB WDM device
[ 1159.091961] cdc_mbim 1-1:1.0 wwan2: register ‘cdc_mbim’ at usb-xhci-hcd.1.auto-1, CDC MBIM, d2:4b:53:20:5a:4d
[ 1400.803320] NETDEV WATCHDOG: wwan2 (cdc_mbim): transmit queue 0 timed out 9800 ms
Arti
If you ignore those error, Is it OK now to set up mbim-network for data establishment?
Hi @jyijyi ,
It is still not wokring.
can you please share with me the exact cdc_mbim driver, config or steps to validate this module on a custom board?
thanks
cdc-mbim is generic driver in linux, it is not from Semtech.
You can validate the module in Ubuntu linux PC.
If it works, then it is your raspberry pi board problem.
BTW, other user did not find problem on MBIM interface with Raspberry pi board:
Here is another user who can make it work on raspberry pi board with EM9293:
Hi @jyijyi ,
I can get the module function with mbim driver but with the qmi driver. I am still facing issues. There is no wwan interface with qmi driver.
Arti
Qmi communication also works in mbim interface
If I use the qmi driver from the semtech website. I do not see any wwan0 device.
I can only see the wwan interface with mbim driver CDC_MBIM driver.
Also if I use both the drivers I get similar issues:
Arti
did you set correctly in AT!USBCOMP?
From kernel log, is it using USB3.0?
Can you try with USB 2.0 hub and see if there is still problem?
Hi @jyijyi ,
I have downloaded the latest driver and documetn from the sierra wirelss site:
Software_Integration_and_Development_Guide_for_Linux_USB_Platforms_R36.pdf
CAn you confirm which driver is appropriate to be used with EM9291?
MBIM or RmNet?
