some part of my code is
#include “adl_global.h”
#include “Sdcard.h”
unsigned char dummybyte[5]={0xFF,0xFF},response=0;
unsigned char buffer[512]=“I have the exact same SD-card, marked wit.I have another card that looks exactly the same apart from the number following SDC/2GB that works fine. I even ordered them together. Both work in an USB-reader that I havthese are uSD-cards SPI is optional, so for all I know the one that works has SPI while the other one doesn’t. I’m unfamiliar with the SD-protocol, so I wouldn’t know exactly when the SPI method fails.What kind of card are you using? If it’s not uSD then the problem must be something else.”;
char buffer2[600]={0};
int sdcard_Init(void)
unsigned char v=0;
Chipselect_Status(1);
for(v = 0; v < 20; v++)
adl_busWrite(HandleSPI,&AccessConfig,1,dummybyte);
Chipselect_Status(0);
v = sdCommandAndResponse(0,1,0); //SEND CMD0
if(v == 1)
TRACE (( 6, "CMD0 Success response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"CMD0 Success\r\n");
else
TRACE (( 6, "CMD0 failed response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"CMD0 failed \r\n");
v = sdCommandAndResponse(8,1,0x000001AA); //SEND CMD8 with 0x000001AA parameter
if(v == 1)
TRACE (( 6, "CMD8 Success response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"CMD8 Success \r\n");
else
TRACE (( 6, "CMD8 failed response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"CMD8 failed \r\n");
v = App_sdCommandAndResponse(41,0,0x40000000); //SEND CMD41
if(v == 0)
TRACE (( 6, "ACMD41 Success response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"ACMD41 Success \r\n");
else
TRACE (( 6, "ACMD41 failed response is %d",v ));
adl_atSendResponse(ADL_AT_UNS,"ACMD41 failed \r\n");
return true;
void sdSendCommand(unsigned char cmd, unsigned long param)
unsigned char send[10]={0};
send[0] = cmd | 0x40;
send[1] = param >> 24;
send[2] = param >> 16;
send[3] = param >> 8;
send[4] = param;
if(cmd==0 || cmd==8)
send[5] = (sdCrc7(send, 5, 0) << 1) | 1;
else
send[5]=0xFF;
adl_busWrite(HandleSPI,&AccessConfig,6,send);
unsigned char sdCommandAndResponse(unsigned char cmd, unsigned char resp, unsigned long param)
unsigned char v=0, i = 0;
do
v=0;
sdSendCommand(cmd, param);
adl_busRead (HandleSPI, &AccessConfig, 1, &v );
adl_busWrite(HandleSPI,&AccessConfig,2,dummybyte);
}while((i++ < 255) && (v != resp));
return v;
unsigned char App_sdCommandAndResponse(unsigned char cmd, unsigned char resp, unsigned long param)
unsigned char v=0, i=0;
do
v=0;
sdSendCommand(55, 0);
return v;
unsigned char sdCrc7(unsigned char* chr,unsigned char cnt,unsigned char crc)
unsigned char i, a;
unsigned char Data;
for(a = 0; a < cnt; a++)
Data = chr[a];
for(i = 0; i < 8; i++)
crc <<= 1;
if( (Data & 0x80) ^ (crc & 0x80) ) {crc ^= 0x09;}
Data <<= 1;
return crc & 0x7F;
unsigned char startwritecmnd=0xFE;
unsigned char SD_writeSingleBlock(unsigned long startBlock,unsigned char Wbuff)
unsigned char v=0;
char buf[50]={0};
unsigned int count=0;
adl_atSendResponse(ADL_AT_UNS,“SDcard writing SingleBlock\r\n”);
v = sdCommandAndResponse(24,0,startBlock<<9); //SEND CMD24 write single block
if(v == 0)
TRACE (( 6, “CMD24 Success response is %d”,v ));
adl_atSendResponse(ADL_AT_UNS,“CMD24 Success\r\n”);
else
TRACE (( 6, “CMD24 failed response is %d”,v ));
adl_atSendResponse(ADL_AT_UNS,“CMD24 failed \r\n”);
adl_busWrite(HandleSPI,&AccessConfig,1,&startwritecmnd); //start writing into sector
adl_busWrite(HandleSPI,&AccessConfig,500,Wbuff);
/* for(i=0; i<512; i++) //write 512 bytes data
adl_busWrite(HandleSPI,&AccessConfig,1,&Wbuff[i]);
*/ adl_busWrite(HandleSPI,&AccessConfig,2,dummybyte);
// adl_busWrite(HandleSPI,&AccessConfig,2,dummybyte);
adl_busRead (HandleSPI, &AccessConfig, 1, &response );
if( (response & 0x1f) != 0x05) //response=0xXXX0AAA1 ; AAA='010' - data accepted
{ //AAA='101'-data rejected due to CRC error
Chipselect_Status(1); //AAA='110'-data rejected due to write error
sprintf(buf,"ret resp is not 0x05, resp is %.2X\r\n",response);
adl_atSendResponse(ADL_AT_UNS,buf);
return response;
// Chipselect_Status(1);
// Chipselect_Status(0);
while(response!=0xfe)
if(count++>0xfffe)
response=0;
adl_atSendResponse(ADL_AT_UNS,“in writing 0xFE failed \r\n”);
return 0;
return 0;
unsigned char SD_readSingleBlock(unsigned long startBlock)
unsigned char v=0,count=0;
adl_atSendResponse(ADL_AT_UNS,“SDcard reading SingleBlock\r\n”);
v = sdCommandAndResponse(17,0,startBlock<<9); //SEND CMD17 read single block
if(v == 0)
TRACE (( 6, “CMD17 Success response is %d”,v ));
adl_atSendResponse(ADL_AT_UNS,“CMD17 Success \r\n”);
else
TRACE (( 6, “CMD17 failed response is %d”,v ));
adl_atSendResponse(ADL_AT_UNS,“CMD17 failed \r\n”);
if(count++>0xfe)
adl_atSendResponse(ADL_AT_UNS,“in reading 0xFE failed \r\n”);
return 0;
adl_busRead (HandleSPI, &AccessConfig, 500, buffer2 );
TRACE (( 6, buffer2));
adl_atSendResponse(ADL_AT_UNS,buffer2);
return 0;
