I configure Wavecom Fastrack Supreme Modem with a private APN and I activate the PDP context (at+cgact). But when the modem turn off and the it turns on I need to set the APN and activate the PDP context again.
How can I save all those settings?
Did you use the the AT+CGDCONT command to specify PDP context parameter values for a PDP context identified by the local context identification parameter.
for example :
AT+CGDCONT=1,“IP”,“xyz.com(APN name)”
then issue at+cgact coammnd to activate the specified PDP context.
The parameters are stored in EEPROM withut using the AT&W command.
You can try using AT&W once.
Thanks.
