SAFE_PWR_REMOVE pin 152 is not toggling on AT!SHUTDOWN is there some thing that need to be configured ?
And is there a specific hardware requirement for the pin ?
I have tried it on our custom board where the signal is going through a level translator
and the Mangoh yellow board where it is just connected to a test point.
both with non customized FW just straight from Sierra ?
Yes the AT command,
The pin seems to be floating while the module is running but never goes high after the command is issued but maybe it goes low for a little haven’t checked if that is the same time as VGPIO goes low
It seems like the system is shutdown fast 5-6 seconds. but the PMIC keeps the pins on for ~25 seconds?
