Hello, I would like to know how I can get the decimals while reading millivolts from Analog Input 1. I see that the format is OIDINTEGER, Which really does me no good If I can only read 8 volts instead of 8.234 volts. Can I get this in a string format? I have tried to read scaledAnalogInput1 and analogInput1, and can only retrieve a WHOLE number.
Hi @Dloe,
Could you please explain further how to perform the testing and how to read voltage values?
Could you also point out which section of the RV55 user guide contains the scaledAnalogInput1, analogInput1 and OIDINTEGER parameters you mentioned? It seems that these parameters are not mentioned in the document.
In addition, please provide the RV55 log file so that I can check further.
