I’ve been trying to SSH into an RV55 but could never access the shell.
The port is right (22), and the credentials too. The connection is a success, but all I get upon logging in is an “OK” message and no prompt. After a while, the connection times out.
From what I’ve read on this forum, this might be an AT terminal ?
If yes, does someone know a way to access the “real” terminal, aka the Linux shell ?
→ When you first logged in, there was only the “OK” message. You have to type ATE1 and then type to see the command.
→ Yes, this is the terminal to type AT command.
→ Use the Telnet or SSH protocol to connect to any AirLink gateway and send AT commands. In the user guide there is no mention of linux shell part on RV55.
