RV50 - Serial to Serial - Master Slave
We have an application with 2 RV50 modems. 1st modem would be connected serial and setup as Master for Modbus, and the 2nd modem end device is serial and setup as slave. Is it possible to have this configuration so that the master device on 1st modem can get modbus data from second modem with both attached as serial on each modem?
Hi @jladams
I’ve attached the guide on configuring a master and slave device for Serial PAD. Generally speaking, PAD performs the same functionality as Modbus RTU.
Serial PAD.pptx (378.5 KB)
Please refer to AirLink RV50/RV50X Software Configuration Guide for more details.
https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-rv-series---configuration-guide/#sthash.MzxBZGSo.dpbs
