RTE Debug Crash
I try to use M2M Studio 1.1.1 and Q24PL001 modem. But RTE debug is imposible. Crash at every 5-10 steps.
Signal SIGSEGV received at crash. There is picture
[attachment=0]Err.png[/attachment]
Debuging thread is Thread [9].
Crash catch at diferent points. My code is working project. I make in in older version of Open AT and Visual Studio 6.
I see Warrings on build too.
**** Internal Builder is used for build               ****
C:\OpenAT\SierraWireless\m2mstudio\tools\mingw\3.4.2\bin\gcc.exe -D__OAT_API_VERSION__=317 -D__REMOTETASKS__ -D__DEBUG_APP__ -IC:\OpenAT\SierraWireless\m2mstudio\dropins\com.wavecom.openat.ide.spm.lib.os.model.3.17.0.02\resources/ADL/hidden -IC:\OpenAT\SierraWireless\m2mstudio\dropins\com.wavecom.openat.ide.spm.lib.os.model.3.17.0.02\resources/ADL/basic -IC:\OpenAT\SierraWireless\m2mstudio\dropins\com.wavecom.openat.ide.spm.lib.os.model.3.17.0.02\resources/ADL/itf -IC:\OpenAT\WorkSpace\Test11\itf -IC:\OpenAT\WorkSpace\Test11\inc -O0 -g3 -Wall -c -fmessage-length=0 -fno-common -osrc\appli.o ..\src\appli.c
C:\OpenAT\SierraWireless\m2mstudio\tools\mingw\3.4.2\bin\dllwrap.exe src\stringx.o src\settings.o src\queue_arr.o src\msg.o src\log.o src\input_filter.o src\i2c.o src\global.o src\floatx.o src\crc.o src\core.o src\commands.o src\call.o src\bsp.o src\appli.o src\WcUtility.o src\Interface.o src\ArmUtility.o -Wl,-( --def=export.def --driver-name g++ C:\OpenAT\SierraWireless\m2mstudio\dropins\com.wavecom.openat.ide.spm.lib.os.model.3.17.0.02\resources\ADL\rte_wmadl_3.17.02.0.0.lib -Wl,-) --dllname=OatAppli.dll
Warning: .drectve `-defaultlib:MSVCRT ' unrecognized
Warning: .drectve `-defaultlib:OLDNAMES ' unrecognized
Build complete for project Test11
Time consumed: 6375  ms.
I test older version of M2M. Problem is identic.
I make tests on diferent mashine. Problems present too.
I lose 3 days to resolve problem. Please help.
Sometimes M2M crash too. There is logs.
We indeed noticed that RTE debugging was not working correctly with M2M Studio when using Open AT OS V3 versions.
I guess that you are using such an old version because you are maintaining an application on a Q24 platform…
Wavecom plan correct this problem in 1.2.0 release?
Now is imposible to work by Q24xxx modem.
Not impossible - you will just have to use a pre-M2MStudio environment (using Eclipse or VisualStudio)
