RSRP/RSRQ/SINR on WP7702
On the WP7702 module both Verizon and R2C variants, are there any guidelines for
RSRP/RSRQ/SINR values to determine Excellent/Good/Poor etc
For example on AirVantage on one of our FX30s
RSSI -49.0RSRP -83.0 RSRQ -17.0. Shows up as Excellent. (this is LTE)
and
RSSI -99.0RSRP -118.0RSRQ -16.0 Shows up as Low (this is GSM)
From specifications -118 RSRP is cell-edge
I want to poll this and determine signal quality
see if this helps:
https://www.digi.com/support/knowledge-base/understanding-lte-signal-strength-values
ok, I am actually using something similar, but wondered if Sierra has any documentation
Secondly, I have an FX30s with R2C sim deployed.
The RAT is default set to GSM,LTE
It did initially connected to LTE but as of now fallen back on GSM. (T-mobile)
Would it be ok to force RAT to LTE, or should the radio pick the strongest possible network available to it
This is the state
root@fx30s:~# microcom /dev/ttyAT
AT!GSTATUS?
!GSTATUS:
Current Time: 118614 Temperature: 42
Reset Counter: 1 Mode: ONLINE
System mode: GSM PS state: Attached
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
GSM band: PCS1900
GSM channel: 609
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
Serving cell: 711 (PCS1900 )
RX level (dBm):-100.1250 LAC: BFCD (49101)
GPRS state: GPRS READY Cell ID: 06CF (1743)
can it register network if you force to LTE by AT!SELRAT?
Not sure if AT!SELACQ can help to switch LTE automatically, you can double check
