Hi, I’m programming an application for the Fastrack Supreme which has to receive a sequence of characters through the UART1 using the RS232 link. I have had problems when receiving more than one character at a time, being the max number of bytes that I can receive in a packet 32 bytes (or characters).
FcmHdl = adl_fcmSubscribe(ADL_FCM_FLOW_V24_UART1,FcmCtrlHandler,FcmDataHandler);
bool FcmCtrlHandler (adl_fcmEvent_e Event)
switch (Event)
case ADL_FCM_EVENT_FLOW_OPENNED:
adl_atSendResponse ( ADL_AT_UNS, "ADL_FCM_EVENT_FLOW_OPENNED\n\r");
adl_fcmSwitchV24State(FcmHdl,ADL_FCM_V24_STATE_DATA);
return TRUE;
bool FcmDataHandler (u16 DataLen, u8 * Data)
char Buffer[150];
sprintf(Buffer," %u : ",DataLen);
adl_fcmSendData (FcmHdl,(u8*)&Buffer,strlen(Buffer));
adl_fcmSendData (FcmHdl,Data,strlen((char*)Data));
return TRUE;
I have tested this code in RTE mode an it works OK. It only returns the data and number of bytes received through the RS232. Beyond are the results in target mode with no hardware flow control (it’s a one way communication), 115200bps, 8 data bits, 1 stop bit:
123456789abcdefghijklmnopqrstuvwxyz
35 : 123456789abcdefghijklmnopqrstuvwxyz
32 : 123456789abcdefghijklmnopqrstuvw÷ 3 : xyz
32 : 123456789abcdefghijklmnopqrstuvw 3 : xyz
32 : 123456789abcdefghijklmnopqrstuvw÷ 3 : xyz N
As you can see there is no answer pattern for the same input. First time I send the test pattern (123456789abcdefghijklmnopqrstuvwx) from the PC to the modem through RS232 it is able to process the whole input (35 characters) however, after this it only process 32 bytes by fcm event, moreover, it adds some ascii control characters (…)
I have read from de Wavecom documentation that max data input from RS232 is limited to 120 bytes, so I don’t understand why I can’t receive more than 32 bytes in one fcm event. Could I been doing something wrong? Why is it receiving such control characters?
Thanks!!
