I went through user guide and implemented all required functions for uart.But still i’m unable to receive the data,
Here is my newly written code.
AFTER OPENING THE UART,STATUS ARE DISPLYED HERE
bool fcmcontrolhandler2(adl_fcmEvent_e event)
switch(event)
case ADL_FCM_EVENT_FLOW_OPENNED:
if(adl_fcmSwitchV24State(fcmhandler2,ADL_FCM_V24_STATE_DATA)==OK)
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"uart flow is opened successfully\n ");
break;
case ADL_FCM_EVENT_FLOW_CLOSED:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,“uart flow is closed\n”);
break;
case ADL_FCM_EVENT_V24_DATA_MODE:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Switched to DATA mode\n");
break;
case ADL_FCM_EVENT_V24_DATA_MODE_EXT:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Switched to DATA mode by Ext App\n");
break;
case ADL_FCM_EVENT_V24_AT_MODE:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Switched to AT mode sucessfully\n");
break;
case ADL_FCM_EVENT_V24_AT_MODE_EXT:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Switched to AT mode by Ext App\n");
break;
case ADL_FCM_EVENT_RESUME:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Resumed\n");
break;
default:
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"Not received\n");
return TRUE;
READ THE DATA FROM UART
bool fcmdatahandler2(u16 datalen,u8 *data)
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,"In reading the data\n");
bool BaudDisplayHandler(adl_atResponse_t *respr)
char *s;
unsigned char sig;
s= respr->StrData;
TRACE (( 1, "Inside BaudDisplayHandler" ));
TRACE (( 1, s ));
//TRACE (( 1, "%d", strlen(s) ));
return FALSE;
Main(){
s8 fcmevnt;
adl_atCmdCreate(“AT+WMFM=0,1,2”, ADL_AT_PORT_TYPE(ADL_PORT_UART1, FALSE), BaudDisplayHandler, “*”, NULL);
adl_atSendResponsePort(ADL_AT_RSP, uart1_port,“Embedded Application : Main”);
adl_atCmdCreate(“at+ipr=9600”, ADL_AT_PORT_TYPE(ADL_PORT_UART2, FALSE), (adl_atRspHandler_t)NULL, NULL);
fcmevnt=adl_fcmSubscribe(ADL_FCM_FLOW_V24_UART2,fcmcontrolhandler2,fcmdatahandler2);
adl_fcmSendData(fcmevnt,”TESTING UART2 SEND FUNCTION\n”,29);
pls help to fix this probelm
thanks
ravee
