jonpio
May 23, 2011, 10:25pm
1
implemented a serial interface using fcm, as per [url]https://forum.sierrawireless.com/t/simple-uart-echo-program/4739/1 ] (thanks josepvr) the AT command version in the examples was
I then buffer the uart receive events data in a buffer. this is then read by a timer event running at max rate 18ms.
If I run at 9600bd I expected to see ~18 bytes per timer period, however I seem to see bursts of precisely 56 bytes at random intervals.
If I then change to 115kbd seem to see bursts of precisely 56 bytes at random intervals.
Is this normal ?
No cigar awneil, I did read the manual
It seems I have 2 devices behaving differently
The one receives 56 bytes at a time significantly slower than the incoming rate, it also often loses first byte & mis behaves at adl_fcmSubscribe()
The other device receives 120 bytes at more or less incoming rate reliably
So it seems to be a firmware issue
Both seem to have some logic going whereby they only pass incoming data when either the buffer is full or some undisclosed inter character timeout.
Yes, I think that is the logic.
Problem is I need to implement exactly the same logic on my side, however I now need to compensate for the fact that they are doing it.
This means my timeout time must be > than the character time of the full buffer ~ 56ms for a 56 buffer & 120ms for a 120 buffer @ 9600 & any future changes / baud changes
ooh the joys of programming someone else’s API
Why?
Can’t you just have FCM writing to a buffer using whatever logic it likes, and your side reading from that buffer using whatever logic it likes?
On of the key uses of “buffers” is to be “elastic” enough to take up the slack like this…
