Hi karlkuhn
Did you work out the issue installing from file system?
I’m getting error -1 returned from adl_fsInstall which isn’t listed in the fs error codes OR the standard adl error codes
From the file system error prototypes:
/* 0 / ADL_FS_NO_ERROR,
/ 1 / ADL_FS_ERR_INVALIDDRIVE,
/ 2 / ADL_FS_ERR_NOTFORMATTED,
/ 3 / ADL_FS_ERR_INVALIDDIR,
/ 4 / ADL_FS_ERR_INVALIDNAME,
/ 5 / ADL_FS_ERR_NOTFOUND,
/ 6 / ADL_FS_ERR_DUPLICATED,
/ 7 / ADL_FS_ERR_NOMOREENTRY,
/ 8 / ADL_FS_ERR_NOTOPEN,
/ 9 / ADL_FS_ERR_EOF,
/ 10 / ADL_FS_ERR_RESERVED,
/ 11 / ADL_FS_ERR_NOTUSEABLE,
/ 12 / ADL_FS_ERR_LOCKED,
/ 13 / ADL_FS_ERR_ACCESSDENIED,
/ 14 / ADL_FS_ERR_NOTEMPTY,
/ 15 / ADL_FS_ERR_INITFUNC,
/ 16 / ADL_FS_ERR_CARDREMOVED,
/ 17 / ADL_FS_ERR_ONDRIVE,
/ 18 / ADL_FS_ERR_INVALIDSECTOR,
/ 19 / ADL_FS_ERR_READ,
/ 20 / ADL_FS_ERR_WRITE,
/ 21 / ADL_FS_ERR_INVALIDMEDIA,
/ 22 / ADL_FS_ERR_BUSY,
/ 23 / ADL_FS_ERR_WRITEPROTECT,
/ 24 / ADL_FS_ERR_INVFATTYPE,
/ 25 / ADL_FS_ERR_MEDIATOOSMALL,
/ 26 / ADL_FS_ERR_MEDIATOOLARGE,
/ 27 / ADL_FS_ERR_NOTSUPPSECTORSIZE,
/ 28 / ADL_FS_ERR_UNKNOWN,
/ 29 / ADL_FS_ERR_DRVALREADYMNT,
/ 30 / ADL_FS_ERR_TOOLONGNAME,
/ 31 / ADL_FS_ERR_NOTFORREAD,
/ 32 / ADL_FS_ERR_DELFUNC,
/ 33 / ADL_FS_ERR_ALLOCATION,
/ 34 / ADL_FS_ERR_INVALIDPOS,
/ 35 / ADL_FS_ERR_NOMORETASK,
/ 36 / ADL_FS_ERR_NOTAVAILABLE,
/ 37 / ADL_FS_ERR_TASKNOTFOUND,
/ 38 / ADL_FS_ERR_UNUSABLE,
/ 39 */ ADL_FS_ERR_CRCERROR,
/* 60 / ADL_FS_ERR_SECURE_PATH = 60,
/ 61 / ADL_FS_ERR_OPEN_FILE,
/ 62 / ADL_FS_ERR_LENGTH_FILE,
/ 63 / ADL_FS_ERR_READ_FILE,
/ 64 / ADL_FS_ERR_WRITE_FILE,
/ 65 / ADL_FS_ERR_FILE_PRESENCE,
/ 66 / ADL_FS_ERR_PASSWORD,
/ 67 */ ADL_FS_ERR_NOT_ALLOWED
From the adl error prototypes:
#define ADL_RET_ERR_PARAM -2 ///< Parameter error
#define ADL_RET_ERR_UNKNOWN_HDL -3 ///< Unknown handler, handle or resource error
#define ADL_RET_ERR_ALREADY_SUBSCRIBED -4 ///< Already subscribed service or resource error
#define ADL_RET_ERR_NOT_SUBSCRIBED -5 ///< Not subscribed service error
#define ADL_RET_ERR_FATAL -6 ///< Fatal error
#define ADL_RET_ERR_BAD_HDL -7 ///< Bad handle or resource error
#define ADL_RET_ERR_BAD_STATE -8 ///< Bad state error
#define ADL_RET_ERR_PIN_KO -9 ///< Bad PIN state error
#define ADL_RET_ERR_NO_MORE_HANDLES -10 ///< The service subscription maximum capacity is reached
#define ADL_RET_ERR_DONE -11 ///< The required iterative process is now terminated
#define ADL_RET_ERR_OVERFLOW -12 ///< The required operation has exceeded the function capabilities
#define ADL_RET_ERR_NOT_SUPPORTED -13 ///< An option, required by the function, is not enabled on the Wireless CPU®, the function is not supported in this configuration
#define ADL_RET_ERR_NO_MORE_TIMERS -14 ///< The function requires a timer subscription, but no more timer resources are available
#define ADL_RET_ERR_NO_MORE_SEMAPHORES -15 ///< The function requires a semaphore allocation, but there are no more semaphores resources
#define ADL_RET_ERR_SERVICE_LOCKED -16 ///< The function was called from a low or high lewel interrupt handler (the function is forbidden in this case)
#define ADL_RET_ERR_SPECIFIC_BASE -20 ///< Beginning of specific errors ranges
No -1 to be found!!
